1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: about GPIB interface
To: [email protected], [email protected]
Date: Fri, 23 Jan 1998 11:17:40 +0900
Bill wrote:
>> Is there anyone who can help with this.  We aren't using these devices
>> here.
>> Rozelle
>I have no experience worth mentioning with support of GPIB on PCs, either
>under dos/windoze or EPICS.  I hope that the following will be helpful
>WRT EPICS on vme.
>AFAIK, only 2 GPIB (IEEE-488) interfaces are supported by EPICS.
>The first is the (in)famous NI-1014 from National Instruments, about which
>John Winans had much to say after getting driver and device support
>working.
>The second is the Hewlett-Packard E2050A "LAN-HPIB Gateway" which has had
>support written by Ben Franksen at BESSY.  I don't know if this has been
>folded into the "official" release, or even as there are plans to do so.
>(IMHO it probably should be, but it's not my call!)
In KEK, we developed a software for Tektronics ET488, which has Ethernet
and GP-IB ports. Host can controll GP-IB device connected to ET-488
over Ethernet. It is not in official release but we are happy to send
a source code. The code has been used on VxWorks on VME only.
>Hmmm - I wonder what would be required to make this code run under EPICS/
>VxWorks on an Intel platform.
< some sentencies dropped>
>Device support for the HP scope shouldn't be too big of a problem.  Take
>a look at devNewSkeletonGpib.c in the EPICS source.  About "all you need
>to do is" to edit command strings that the 'scope will understand into
>the param strings.  While it may not seem obvious how to do that, after
>you get the first one working it's fairly straight-forward.  Johns' note
>in the documentation on the web should be a good starting point.
>All of my babbling here seems pretty bland to me, but something tells
>me I'd best include a disclaimer.
We wrote a small tool nambed GDL to help a our GP-IB user. GDL translates
the follwing description,
Device(Tek2430)
/* Function proto types */
STATIC int rd_wf();
NameTable offOn = "OFF", "ON";
EfastTable userOffOn = "USER OFF",  "USER ON";
EfastTable Ch1Range=
        "CH1 VOLTS:2E-3",  "CH1 VOLTS:5E-3",  "CH1 VOLTS:1E-2"
        ,  "CH1 VOLTS:2E-2",  "CH1 VOLTS:5E-2",  "CH1 VOLTS:1E-1"
        ,  "CH1 VOLTS:2E-1",  "CH1 VOLTS:5E-1",  "CH1 VOLTS:1"
        ,  "CH1 VOLTS:2",  "CH1 VOLTS:5"
SrqHandler=mySrqHandler UNSolicited_SRQ;
ParamTable{
        set_ch1_volt    {rec=ai, command="CH1? VOL\r", conv="CH1 VOLTS:%lf",
leng=32}
        get_ch1_volt    {rec=ao, command="CH1 VOL:%.lf\r"}
into the device support code attached at the end of this e-mail.
We didn't put it on the net, but someone has a interest on this tool,
we will make it avaiable on the net.
Noboru Yamamot
KEK, JAPAN
=========== output from GDL tool ========================================
/* @(#)GNC Version 1.0: : Tek2430 */
 * The following define statements are used to declare the names to be used
 * for the dset tables.
 * NOTE: The dsets are referenced by the entries in the command table.
#define	DSET_AI    devAiTek2430Gpib
#define	DSET_AO    devAoTek2430Gpib
#define	DSET_BI    devBiTek2430Gpib
#define	DSET_BO    devBoTek2430Gpib
#define	DSET_SI    devSiTek2430Gpib
#define	DSET_SO    devSoTek2430Gpib
#define	DSET_LI    devLiTek2430Gpib
#define	DSET_LO    devLoTek2430Gpib
#define	DSET_MBBI  devMbbiTek2430Gpib
#define	DSET_MBBO  devMbboTek2430Gpib
#define	DSET_WF    devWfTek2430Gpib
#include	<vxWorks.h>
#include	<taskLib.h>
#include	<rngLib.h>
#include	<types.h>
#include	<stdioLib.h>
#include	<string.h>
#include	<alarm.h>
#include	<cvtTable.h>
#include	<dbDefs.h>
#include	<dbAccess.h>
#include	<devSup.h>
#include	<recSup.h>
#include	<drvSup.h>
#include	<link.h>
#include	<module_types.h>
#include	<dbCommon.h>
#include	<aiRecord.h>
#include	<aoRecord.h>
#include	<biRecord.h>
#include	<boRecord.h>
#include	<mbbiRecord.h>
#include	<mbboRecord.h>
#include	<stringinRecord.h>
#include	<stringoutRecord.h>
#include	<longinRecord.h>
#include	<longoutRecord.h>
#include	<waveformRecord.h>
#include	<drvGpibInterface.h>
#include	<devCommonGpib.h>
#define STATIC static
STATIC long	init_dev_sup(), report();
# line 3 "../src/temp.gt"
STATIC int rd_wf();
static	struct  devGpibParmBlock devSupParms;
 * Define all the dset's.
 * Note that the dset names are provided via the #define lines at the top of
 * this file.
 * Other than for the debugging flag(s), these DSETs are the only items that
 * will appear in the global name space within the IOC.
 * The last 3 items in the DSET structure are used to point to the parm
 * structure, the  work functions used for each record type, and the srq
 * handler for each record type.
gDset DSET_AI   = {6, {report, init_dev_sup, devGpibLib_initAi, NULL,
	devGpibLib_readAi, NULL, (DRVSUPFUN)&devSupParms,
	(DRVSUPFUN)devGpibLib_aiGpibWork, (DRVSUPFUN)devGpibLib_aiGpibSrq}};
gDset DSET_AO   = {6, {NULL, NULL, devGpibLib_initAo, NULL,
	devGpibLib_writeAo, NULL, (DRVSUPFUN)&devSupParms,
	(DRVSUPFUN)devGpibLib_aoGpibWork, NULL}};
gDset DSET_BI   = {5, {NULL, NULL, devGpibLib_initBi, NULL,
	devGpibLib_readBi, (DRVSUPFUN)&devSupParms,
	(DRVSUPFUN)devGpibLib_biGpibWork, (DRVSUPFUN)devGpibLib_biGpibSrq}};
gDset DSET_BO   = {5, {NULL, NULL, devGpibLib_initBo, NULL,
	devGpibLib_writeBo, (DRVSUPFUN)&devSupParms,
	(DRVSUPFUN)devGpibLib_boGpibWork, NULL}};
gDset DSET_SI   = {5, {NULL, NULL, devGpibLib_initSi, NULL,
	devGpibLib_readSi, (DRVSUPFUN)&devSupParms,
	(DRVSUPFUN)devGpibLib_stringinGpibWork, (DRVSUPFUN)devGpibLib_stringinGpibSrq}};
gDset DSET_SO   = {5, {NULL, NULL, devGpibLib_initSo, NULL,
	devGpibLib_writeSo, (DRVSUPFUN)&devSupParms,
	(DRVSUPFUN)devGpibLib_stringoutGpibWork, NULL}};
gDset DSET_LI   = {5, {NULL, NULL, devGpibLib_initLi, NULL,
	devGpibLib_readLi, (DRVSUPFUN)&devSupParms,
	(DRVSUPFUN)devGpibLib_liGpibWork, (DRVSUPFUN)devGpibLib_liGpibSrq}};
gDset DSET_LO   = {5, {NULL, NULL, devGpibLib_initLo, NULL,
	devGpibLib_writeLo, (DRVSUPFUN)&devSupParms,
	(DRVSUPFUN)devGpibLib_loGpibWork, NULL}};
gDset DSET_MBBI = {5, {NULL, NULL, devGpibLib_initMbbi, NULL,
	devGpibLib_readMbbi, (DRVSUPFUN)&devSupParms,
	(DRVSUPFUN)devGpibLib_mbbiGpibWork, (DRVSUPFUN)devGpibLib_mbbiGpibSrq}};
gDset DSET_MBBO = {5, {NULL, NULL, devGpibLib_initMbbo, NULL,
	devGpibLib_writeMbbo, (DRVSUPFUN)&devSupParms,
	(DRVSUPFUN)devGpibLib_mbboGpibWork, NULL}};
gDset DSET_WF   = {5, {NULL, NULL, devGpibLib_initWf, NULL,
	devGpibLib_readWf, (DRVSUPFUN)&devSupParms,
	(DRVSUPFUN)devGpibLib_wfGpibWork, (DRVSUPFUN)devGpibLib_wfGpibSrq}};
 * Debugging flags that can be accessed from the shell.
int Tek2430Debug = 0;
extern int ibSrqDebug;		/* declared in the GPIB driver */
 * Use the TIME_WINDOW defn to indicate how long commands should be ignored
 * for a given device after it times out.  The ignored commands will be
 * returned as errors to device support.
 * Use the DMA_TIME to define how long you wish to wait for an I/O operation
 * to complete once started.
 * These are to be declared in 60ths of a second.
#define TIME_WINDOW	600		/* 10 seconds */
#define DMA_TIME	60		/* 1 second */
 * Strings used by the init routines to fill in the znam, onam, ...
 * fields in BI and BO record types.
static char                *offOnList[] = { "OFF", "ON" };
static struct devGpibNames offOn = { 2, offOnList, NULL, 1 };
 * String arrays for EFAST operations.  Note that the last entry must be
 * NULL.
 * On input operations, only as many bytes as are found in the string array
 * elements are compared.  If there are more bytes than that in the input
 * message, they are ignored.  The first matching string found (starting
 * from the 0'th element) will be used as a match.
 * NOTE: For the input operations, the strings are compared literally!  This
 * can cause problems if the instrument is returning things like \r and \n
 * characters.  You must take care when defining input strings so you include
 * them as well.
static char *(userOffOn[])={"USER OFF","USER ON",NULL};
static char *(Ch1Range[])={"CH1 VOLTS:2E-3","CH1 VOLTS:5E-3","CH1 VOLTS:1E-2","CH1 VOLTS:2E-2","CH1 VOLTS:5E-2","CH1 VOLTS:1E-1","CH1 VOLTS:2E-1","CH1 VOLTS:5E-1","CH1 VOLTS:1","CH1 VOLTS:2","CH1 VOLTS:5",NULL};
 * Array of structures that define all GPIB messages
 * supported for this type of instrument.
static struct gpibCmd gpibCmds[] = {
    /* CMMAND 0 set_ch1_volt */
  {&DSET_AI, GPIBREAD, IB_Q_LOW, "CH1? VOL\r", "CH1 VOLTS:%lf", 0, 32, NULL, 0, 0, NULL, NULL, -1 },
    /* CMMAND 1 get_ch1_volt */
  {&DSET_AO, GPIBWRITE, IB_Q_LOW, NULL, "CH1 VOL:%.lf\r", 0, 32, NULL, 0, 0, NULL, NULL, -1 }
/* The following is the number of elements in the command array above.  */
#define NUMPARAMS	sizeof(gpibCmds)/sizeof(struct gpibCmd)
 * Structure containing the user's functions and operating parameters needed
 * by the gpib library functions.
 * The magic SRQ parm is the parm number that, if specified on a passive
 * record, will cause the record to be processed automatically when an
 * unsolicited SRQ interrupt is detected from the device.
 * If the parm is specified on a non-passive record, it will NOT be processed
 * when an unsolicited SRQ is detected.
 * In the future, the magic SRQ parm records will be processed as "I/O event
 * scanned"... not passive.
static struct  devGpibParmBlock devSupParms = {
  &Tek2430Debug,         /* debugging flag pointer */
  -1,                   /* device does not respond to writes */
  TIME_WINDOW,          /* # of clock ticks to skip after a device times out */
  NULL,                 /* hwpvt list head */
  gpibCmds,             /* GPIB command array */
  NUMPARAMS,            /* number of supported parameters */
  -1,			/* magic SRQ param number (-1 if none) */
  "devTek2430Gpib",	/* device support module type name */
  DMA_TIME,		/* # of clock ticks to wait for DMA completions */
  mySrqHandler,			/* SRQ handler function (NULL if none) */
  NULL			/* secondary conversion routine (NULL if none) */
 * Initialization for device support
 * This is called one time before any records are initialized with a parm
 * value of 0.  And then again AFTER all record-level init is complete
 * with a param value of 1.
STATIC long
init_dev_sup(int parm)
  return(devGpibLib_initDevSup(parm,&DSET_AI));
 * Print a report of operating statistics for all devices supported by this
 * module.
 * This function will no longer be required after epics 3.3 is released
STATIC long
report(void)
  return(devGpibLib_report(&DSET_AI));
 * c code
Prev: Re: new record support Nick Rees
Next: Re: about GPIB interface Benjamin Franksen
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: about GPIB interface Bill Brown
Next: new record support Jeffrey Mcdonald
