Dear Sir
I am a graduate student of POSTECH in Korea.
I must install EPICS in order to develope longitudinal feedback system for the
PLS (=Pohang Light Source / PAL) storage.
I installed epics base with William ([email protected]),
Rozelle Wright ([email protected]), Noboru Yamamoto ([email protected])
and Steve Lewis ([email protected])'s help. I thank them very much.
I tried to compile EPICS extensions which is composed with
extensions2-17-97.Tar.gz and extensions2-17-97.config.gz files.
But I met some errors, So I cann't install epics extensions in my machine.
My mcahine is Sun Enterprise Server 450
OS is Solaris2.6
Target is mv162
VxWorks is Tornado-1.0.1 which is located at /usr/local/tornado-1.0.1
EPICS is epics-3.13.0.b11 which is located at /usr/local/epics
EPICS base is located at /usr/local/epics/base
EPICS base tools is loacted at /usr/local/epics/base/src/tools
XRT/GRAPH is located at /usr/local/xrt_pds-1.0.0
which is the XRT/PDS-1.0.0.
When I compile the medm, I met one error:
/opt/SUNWspro/bin/cc -Xa -O -I../../graphX -I../../xc -I/usr/dt/include
-I/usr/openwin/include -I/usr/local/xrt_pds-1.0.0/include/Xm -DSOLARIS
-I. -I.. -I/usr/local/epics/base/include -DUNIX -c ../help_protocol.c
"../help_protocol.c", line 75:
warning: argument #4 is incompatible with prototype:
prototype: pointer to function() returning void :
"/usr/dt/include/Xm/Protocols.h", line 89
argument : pointer to function(pointer to struct
_WidgetRec {struct _CorePart {..} core},
pointer to char, pointer to char) returning p...
gnumake[3]: *** No rule to make target `/usr/local/epics/extensions/lib/solaris/libUnix.a',
needed by `medm'. Stop.
gnumake[3]: Leaving directory `/usr/local/epics-3.13.0.b11/extensions/src/medm/medm/O.solaris'
gnumake[2]: *** [arch] Error 2
gnumake[2]: Leaving directory `/usr/local/epics-3.13.0.b11/extensions/src/medm/medm'
gnumake[2]: Entering directory `/usr/local/epics-3.13.0.b11/extensions/src/medm/medm'
gnumake[1]: Leaving directory `/usr/local/epics-3.13.0.b11/extensions/src/medm/medm'
codia[119]#
Question[1] anybody know why that error happened ?
Question[2] in /usr/local/epics/config/CONFIG_SITE.Vx.68k
I don't know about the variable
# Epics defs
HIDEOS=/home/phoebus/HIDEOS/hideos_vx
I set the variable such as
HIDEOS=/usr/local/hideos/hideos
at the place which some directories are included:
codia[61]# pwd
codia[62]# ls
CVS/ apps/ epics/ tools/
MakeArch config/ hideos_sys/ vxworks_sys/
Makefile doc/ install/
Is this variable setting is right ?
Question[3] I cann't compile the iv_epics_3.1.tar.gz in my machine.
I complied that such as:
codia[1]# cd /usr/local
codia[2]# gzip -d < iv_epics_3.1.tar.gz | tar xvf -
codia[3]# mv iv_epics interviews-3.1
codia[4]# cd interviews-3.1
codia[5]# setenv HOST_ARCH solaris
codia[6]# setenv X11_LIB /usr/openwin/lib
codia[7]# setenv X11_INC /usr/openwin/include
codia[8]# setenv XCONFIGDIR /usr/openwin/lib/X11/config
codia[9]# setenv InstallCmd /usr/ucb/install
codia[10]# vi src/config/InterViews/local.def
codia[11]# gnumake World XCONFIGDIR=/usr/openwin/lib/X11/config
<-- one line --> InstallCmd=/usr/ucb/install
codia[12]# gnumake install XCONFIGDIR=/usr/openwin/lib/X11/config
After install the interviews-3.2, I linked
codia[13]# ln -s /usr/local/interviews-3.1/installed /usr/local/interviews
But I cann't find the /usr/local/interviews/lib/O.solaris.
Only "all" I can find. So, linking of libIV.so and libUnidraw.so
is impossible.
But in /usr/local/interviews/bin/O.solaris/, Some files are located:
codia[100]# pwd
/usr/local/interview/bin/O.solaris
codia[101]# ls
cpu* ibmkmf* ivmkmf* remind*
codia[102]#
I think that my compiling of interviews has some problems.
Please, tell me the right way how I can installed iv_epics_3.1.tar.gz
Question[4] in /usr/local/epics/config/CONFIG_SITE.Unix.solaris
WINGZ_INC = /opt/local/Wingz2/incl
WINGZ_LIB = /opt/local/Wingz2/lib/libiattools.a
QUESTWIN = /usr/local/questwin
DP_LIB = /opt/local/lib
DP_INC = /opt/local/include
BLT_LIB = /opt/local/lib
BLT_INC = /opt/local/include
I don't know about "DP" and "BLT" "QUESTWIN" and "WINGZ"
where can I obtain those source file ?
I want to install the "DP" and "BLT", But I don't know the place where
I can obtain those source.
Please tell me the place where I can obtain those source tar files.
Question[5] two config files:
extensions4-15-97.config.Tar.gz and
extensions2-17-97.config.Tar.gz
which must I use in order to compile the extensions2-17-97.Tar.gz
what difference of above two config files ?
Question[6] in extensions2-17-97.Tar.gz, README describes setting path
such as:
set path = ($path EPICS/base/tools ~~~~ EPICS/extensions/bin/HOST_ARCH)
does "EPICS/base/tools" mean "EPICS/base/src/tools" ?
And must I make a directory such as "EPICS/extensions/bin/HOST_ARCH"
(=/usr/local/epics/extensions/bin/solaris) ?
Questions[7] In building all extensions with GNU Compiler (gcc, g++), some errors happened :
gnumake[4]: Entering directory `/usr/local/epics-3.13.0.b11/extensions/src/xmca/O.solaris'
rm -f xmca.o
/usr/local/bin/gcc -ansi -O -D_NO_PROTO -I/usr/local/epics/extensions/include
-I/usr/local/epics/extensions/include -I/usr/dt/include -I/usr/openwin/include -DSOLARIS -I.
-I.. -I/usr/local/epics/base/include -DUNIX -c ../xmca.c
../xmca.c:52: chandata.h: No such file or directory
gnumake[4]: *** [xmca.o] Error 1
gnumake[4]: Leaving directory `/usr/local/epics-3.13.0.b11/extensions/src/xmca/O.solaris'
gnumake[3]: *** [arch] Error 2
gnumake[3]: Leaving directory `/usr/local/epics-3.13.0.b11/extensions/src/xmca'
gnumake[3]: Entering directory `/usr/local/epics-3.13.0.b11/extensions/src/xmca'
gnumake[2]: Leaving directory `/usr/local/epics-3.13.0.b11/extensions/src/xmca'
gnumake[1]: Leaving directory `/usr/local/epics-3.13.0.b11/extensions/src'
codia[177]#
Pleae, tell me the way how I can cure above errors ?
Question[8] in two "ar" "ld" and "as" etc, (=/usr/ccs/bin/as (Solaris as), /usr/local/bin/as(GNU as),
(/usr/ccs/bin/ar(Solaris ar), /usr/local/bin/ar (GNU ar) )
which I must use in order to compile epics extensions
i.e GNU or Solaris ?
Thank you for reading my mail !
I hope that someone would help me kindly.
from Yujong Kim, POSTECH
[email protected]
[email protected]
Re: Stops in the motor record Graham Waters
EPICS listserver archives phrase finder Bill McDowell
<1998>
2025
Re: Stops in the motor record Hubert Yamada
<1998>
2025
