Bonjour,
I'm starting using EPICS and I've written a simple SNL code to get
a 32 DOUT board (XVME220) flashing in sequence its different channels
(great stuff!)
I understand using a periodic scan might be more appropriate,
but I'm still a bit puzzled with what might go wrong here:
basically the whole IOC - after a seemingly random number of loop,
hangs and there's no other way but a nice clean reboot.
Before that all seems to work fine.
Your input would be greatly appreciated.
I use two (16 states) mbbo PV for my 32 outputs
both mbbo connect to the same hardware OUT
one mbbo sends values 0x1 0x2 0x4 ... 0x8000
the other 0x10000 .. 0x80000000
NB: I monitor these channels with the edd/dm 'byte' widget.
one for the 16 lower first states (works fine),
another for the 16 higher one (mask on bit 16 to 31)
-> the widget always shows bit 31 True (0x10000 looks like 0x8001____)
-> the widget shows 0x80000000 as 0xffff____
I attach the SNL source.
regards,
matthieu
Matthieu Bec Isaac Newton Group
phone: +34 22 425427 Apartado de Correos 321
fax : +34 22 425401 38780 Santa Cruz de La Palma
email: [email protected] Canary Islands, Spain
program hangtest
* I use two (16 states) mbbo PV for my 32 outputs
long hiout;
long lowout;
* the currently selected output channel
short rampId=0;
assign hiout to "small:hi_out";
assign lowout to "small:low_out";
ss flashramp {
state RUN {
when (delay(0.1)) {
* flash ramp: selects dout channel 0 ->
31 sequentially
rampId = (rampId+1) % 32;
if (rampId<16) {
lowout=rampId;
pvPut(lowout);
else {
hiout=rampId-16;
pvPut(hiout);
} state RUN
Re: CA Server Steven M Beard
RE: CA Server john sinclair
<1998>
2025
Re: EPICS and WindRiver's Tornado Nick Rees
Re: help ? SNL hangs, EDD/DM 'byte' widget bugs Ned Arnold
<1998>
2025
