> Bonjour,
> I'm starting using EPICS and I've written a simple SNL code to get
> a 32 DOUT board (XVME220) flashing in sequence its different channels
> (great stuff!)
> I understand using a periodic scan might be more appropriate,
> but I'm still a bit puzzled with what might go wrong here:
> basically the whole IOC - after a seemingly random number of loop,
> hangs and there's no other way but a nice clean reboot.
> Before that all seems to work fine.
> Your input would be greatly appreciated.
matthieu,
I didn't see anything wrong with your sequence program. What version of
EPICS ?, on what CPU ? on what vxWorks ? Just how does the ioc "hang" ?
Can you still interact with the vxWorks shell ? Is there a particular
task consuming all the CPU (use spy) ?
By the way, here is a three record database that does the same thing.
Ned
record(calcout,"counter") {
field(SCAN,".1 second")
field(CALC,"A<31?A+1:0")
field(INPA,"counter.VAL NPP NMS")
record(calcout,"low_out_set") {
field(CALC,"A<=16")
field(INPA,"counter.VAL CP NMS")
field(OUT,"small:low_out.VAL PP MS")
field(OOPT,"When Non-zero")
field(DOPT,"Use OCAL")
field(OCAL,"A%16")
record(calcout,"hi_out_set") {
field(CALC,"(A>=16)||(A=0)")
field(OUT,"small:hi_out.VAL PP MS")
field(OCAL,"A%16")
May 98 genda Bob Dalesio
Re: CA Server and EPICS Bill Lavender
<1998>
2025
help ? SNL hangs, EDD/DM 'byte' widget bugs Matthieu Bec
<1998>
2025
