1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Failure of assert within dbEvet.c
To: [email protected], [email protected]
Date: Tue, 6 Oct 1998 08:55:19 -0600
Hi Rosemary,
I think you must be running the sequencer and
there may be a problem with it.
There were several bugs fixed in the sequencer between the
versions sent out with Beta11 and the one sent out with Beta12
and there is also a special version that William Lupton at Keck
is using, so it would be helpful to know which one you have.
When you first start
up the sequencer on the ioc by
typing
seq &<your sequence program name>
it should tell you what version you are using.
In my case I type:
 seq & llrfFillHistory
and it replies:
@(#)SNC/SEQ Version 1.9.2.Beta12 : Fri Sep  4 10:42:22 1998
which means it is Version 1.9.2.Beta12.
Could you please tell us what Version of the sequencer you are using?
Rozelle
|Rozelle Wright              Phone (505) 667-4804       |
|Los Alamos Natl Labs LANSCE-8  FAX (505) 665-5107      |
|PO Box 1663 MS-H820         Group Office (505) 667-6087|
|Los Alamos, NM 87545        email : [email protected]   |
> From [email protected] Mon Oct  5 21:06 MDT 1998
> Date: Mon, 5 Oct 1998 17:00:47 -1000
> Subject: Failure of assert within dbEvet.c
> Content-Type: text
> Content-Length: 1095
> X-Lines: 36
> Aloha,
> Any ideas with regard to the below?
> EV seqAux: A call to "assert (ev_que->evUser->nDuplicates>=1u)" failed in ../dbEvent.c at 1036
> Please send a copy of the output from "tt (0xb635d8)" and a copy of this message
> to the author or "[email protected]"
> This problem occurred in "@(#)Version R3.13.0.beta.11 $$Date: 1997/07/14 14:04:12 $$"
> cp_control (ready): offset
> task: 0Xc7b338 taskwd
> task b635d8 EV seqAux suspended
> -> tt (0xb635d8)
>  2cb98 _vxTaskEntry   +c  : _event_task (c4e188, a63478, b6ce60, 0, 0, 0)
> e5367c _event_task    +cc : e53858 (a63478, ffffffff, 0, b2000, 4401fc3, 8)
> e53968 _event_task    +3b8: _epicsAssert (e53130, 40c, e53838, 0, e7a208, 4)
> e6fcd8 _epicsAssert   +8c : _taskSuspend (0, e6fc10, e53838, e53130, 40c, &_dtiPixX)
> value = 0 = 0x0
> Mahalo,
> Rosemary Alles
> Software Engineer
> Canada France Hawaii Telescope
> e-mail: <[email protected]>
> Phone : 808-885-3178
> Fax   : 808-885-7288
Prev: Re: Motif 2.1 and EPICS Thomas . Birke
Next: Re: More than four char's in a field name Marty Kraimer
Index: 1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Failure of assert within dbEvet.c Rosemary Alles
Next: time sync between iocs Marty Kraimer
