1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: time sync between iocs
To: [email protected]
Date: Tue, 06 Oct 1998 10:55:52 -0500
At aps we modified drvTS so that a a master timing ioc could, when
commanded, resync with a ntp or unix time server.
While testing we found a couple of other problems.
1) async clients did not properly resync with an ioc time master.
2) If an ioc is syncing with an ntp or unix server then everything works
ok if the client stays within a second of the server or gets off by > 20
seconds. If, however, it gets off by 1 to 20 seconds it may stay off by
1 to 20 seconds for an arbitrary period of time.
This fix will be in next base release.
There is also a version of drvTS.h and drvTS.c that fixes the problem
for beta11.
Marty Kraimer
Prev: Re: More than four char's in a field name Marty Kraimer
Next: PEP VM162 and VM172 Stephen Pate
Index: 1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Failure of assert within dbEvet.c Rozelle Wright
