1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: Keck portable CA server usage
To: [email protected]
Cc: [email protected]
Date: Fri, 06 Nov 1998 10:25:36 -0800 (PST)
>The software seems to be reliable and efficient. We had some crashing
>problems (with large arrays) under Beta11 but we believe that these are
>fixed in Beta12 (the problem was in GDD, not in the CA server library).
>We do still have a problem with asynchronous i/o that completes after
>the CA client has exited; we would be interested to hear other peoples'
>experience of asynchronous i/o.
Hi William -
I attempted to use asynch I/O in my CA server for BPM (beam position
monitor) acquisition.  But most clients just don't have a long enough wait
for gets to complete.  I also had some problems with the CA server crashing
when a client exits before IO completion (I was using beta11 - not tried it
with beta12).  I didn't explore this problem further since I didn't want to
change all our EPICS clients to use longer get timeouts.  Instead,
for now, people have to use monitors when they want BPM data and, if they
are the first one to post the monitors, they have to wait for data with good
status to come if they want to use the data.  If they do a get, they'll
just get zero data with a "timeout" status.  The fundamental problem here is
that our existing old non-EPICS control system does not cache BPM data
anywhere - all acqs are done on-demand using about 30 different acq parameters
set up by the clients before the acq.
This situation is not ideal and obviously needs more thought and work as
time permits.
Stephanie
Prev: linear conversion in ai & ao records ts
Next: some database link / simulation issues William Lupton
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Keck portable CA server usage William Lupton
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
