1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: some database link / simulation issues
To: [email protected]
Date: Fri, 6 Nov 1998 10:12:48 -1000
Dear all,
  I was just running a portable CA server with a sufficiently high debug
level to see all the CA name resolution broadcasts (e.g. "excas -d3")
and there are a heck of a lot. I think that the number is higher than I
expected for two reasons:
1. link fields of the form " NPP" etc. (which are arguably a bug but
   which can happen if the Capfast value is something like "$(var) NPP"
   and $(var) is blank) result in a search for a PV called "NPP"
2. INP/OUT fields for records that are currently simulating still result
   in name resolution broadcasts for the referenced channels (if you are
   simulating, the referenced channels are quite likely not to exist)
  Are either of both of the behaviors expected and/or easy to change?
  William
Prev: Re: Keck portable CA server usage saa
Next: Re: SNL request William Lupton
Index: 1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: some database link / simulation issues Jeff Hill
