1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: R3.13.1
To: Ralph Lange <[email protected]>
Cc: [email protected]
Date: Wed, 16 Dec 1998 11:32:59 -0500 (EST)
On Wed, 16 Dec 1998, Ralph Lange wrote:
> > I do:
> >   makeBaseApp.pl -t example example
> > and it complains:
> >   Not a directory Copying /usr/util/epics/base/templates/makeBaseApp/top/ ...
> >   exampleApp/Makefile/.wind -> exampleApp/Makefile/.wind at /usr/util/ ...
> >   epics/base/bin/sun4/makeBaseApp.pl line 249.
> > Any suggestions?
> This behaviour is not intended nor understandable.
> There is no file
> {EPICS_BASE}/templates/makeBaseApp/top/exampleApp/Makefile/.wind
> within any base distribution. .../exampleApp/Makefile is a plain file, not
> a directory.
> Please make sure the tree under {EPICS_BASE}/templates/makeBaseApp/top
> looks as follows:
> If your template tree looks like this, makeBaseApp should be able to copy
> it. If the error still occurs, please send the debug output of makeBaseApp.
The template tree looks correct; the debug output of makeBaseApp.pl follows:
makeBaseApp.pl -d -t example example
Command line / environment options validated:
 Templ-Top: /usr/util/epics/base/templates/makeBaseApp/top
Templ-Type: example
Templ-Name: exampleApp
     opt_i:
      arch:
EPICS-Base: /usr/util/epics/base
Copying file /usr/util/epics/base/templates/makeBaseApp/top/Makefile -> Makefile
Creating directory config
Copying file /usr/util/epics/base/templates/makeBaseApp/top/config/CONFIG -> config/CONFIG
Copying file /usr/util/epics/base/templates/makeBaseApp/top/config/CONFIG_APP -> config/CONFIG_APP
Copying file /usr/util/epics/base/templates/makeBaseApp/top/config/RELEASE -> config/RELEASE
Copying file /usr/util/epics/base/templates/makeBaseApp/top/config/RULES.Db -> config/RULES.Db
Copying file /usr/util/epics/base/templates/makeBaseApp/top/config/RULES.Host -> config/RULES.Host
Copying file /usr/util/epics/base/templates/makeBaseApp/top/config/RULES.Vx -> config/RULES.Vx
Copying file /usr/util/epics/base/templates/makeBaseApp/top/config/RULES.ioc -> config/RULES.ioc
Copying file /usr/util/epics/base/templates/makeBaseApp/top/config/RULES.iocBoot -> config/RULES.iocBoot
Copying file /usr/util/epics/base/templates/makeBaseApp/top/config/RULES_ARCHS -> config/RULES_ARCHS
Copying file /usr/util/epics/base/templates/makeBaseApp/top/config/RULES_DIRS -> config/RULES_DIRS
Copying file /usr/util/epics/base/templates/makeBaseApp/top/config/RULES_TOP -> config/RULES_TOP
Copying file /usr/util/epics/base/templates/makeBaseApp/top/config/makeDbDepends.pl -> config/makeDbDepends.pl
Copying file /usr/util/epics/base/templates/makeBaseApp/top/config/makeIocCdCommands.pl -> config/makeIocCdCommands.pl
Copying file /usr/util/epics/base/templates/makeBaseApp/top/config/replaceVAR.pl -> config/replaceVAR.pl
Creating template structure for example (of type exampleApp)
Creating directory exampleApp
Copying file /usr/util/epics/base/templates/makeBaseApp/top/exampleApp/Makefile -> exampleApp/Makefile
Not a directory Copying /usr/util/epics/base/templates/makeBaseApp/top/exampleApp/Makefile/.wind -> exampleApp/Makefile/.wind at /usr/util/epics/base/bin/sun4/makeBaseApp.pl line 249.
John Sinclair
[email protected]
Oak Ridge National Lab
423-576-6362   423-574-1268 (fax)
Re: R3.13.1 Ralph Lange
Prev: Re: R3.13.1 Ralph Lange
Next: tech-talk subscription Kim Haddock
Index: 1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: R3.13.1 Ralph Lange
