1994  1995  1996  1997  1998  <1999>  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  <1999>  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Slow booting ioc
To: Jeff Hill <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Thu, 21 Jan 1999 15:54:30 -0600
Jeff Hill wrote:
> Typically I see these delays only once during the boot, but sometimes (usually) it is the
> symbol table, and not the first file loaded (the system image) that seems to delay the boot
> for an extended period. This delay appears to track with certain models of single board computers
> (SBCs) when other SPCs models boot normally off the same server. I dont claim to fully understand
> this behavior. The systems here with this affliction boot reliably, but continue to tax our patience.
This makes sense - the symbol table is the first file loaded by the new
running system image; AIUI the problam occurs because the new system is
re-using a port number which the boot prom already used while loading the
boot image.  I guess you might be able to get around this if you could
identify where in the boot image this counter is initialised, and ensure
that the value used by the disk image is significantly different to the
value used by the boot prom.  That might not be easy to find without
source code, although I guess it *could* be done.
- Andrew
New country, new job, new address, new .signature; same old Andrew Johnson
RE: Slow booting ioc Jeff Hill
Prev: Re: Slow booting ioc Garrett D. Rinehart
Next: RE: Slow booting ioc Jeff Hill
Index: 1994  1995  1996  1997  1998  <1999>  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Slow booting ioc Jeff Hill
Next: RE: Slow booting ioc Steve Lewis
