On Thursday, January 21, 1999 2:55 PM, Andrew Johnson [SMTP:[email protected]] wrote:
> Jeff Hill wrote:
> > Typically I see these delays only once during the boot, but sometimes (usually) it is the
> > symbol table, and not the first file loaded (the system image) that seems to delay the boot
> > for an extended period. This delay appears to track with certain models of single board computers
> > (SBCs) when other SPCs models boot normally off the same server. I dont claim to fully understand
> > this behavior. The systems here with this affliction boot reliably, but continue to tax our patience.
> This makes sense - the symbol table is the first file loaded by the new
> running system image; AIUI the problam occurs because the new system is
> re-using a port number which the boot prom already used while loading the
> boot image.
One can only assume that the boot ROM code is correctly written so that it shuts down
(closes) its TCP boot connection before jumping into the newly loaded system image.
Therefore I don't fully understand why this problem occurs most frequently when the symbol
table is loaded. Perhaps the problem is that they don't wait long enough for the boot
TCP connection to fully shutdown the TCP state machine before jumping into the newly
loaded system image. Frequently TCP connections linger briefly while the TCP disconnect
sequence is completing after the socket "close()" call has already returned.
Jeff
Re: Slow booting ioc Andrew Johnson
RE: Slow booting ioc Mark Rivers
<1999>
2025
Re: Slow booting ioc Garrett D. Rinehart
<1999>
2025
