1994  1995  1996  1997  1998  <1999>  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  <1999>  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: CA on alphas
To: epics tech-talk <[email protected]>
Date: Thu, 11 Feb 1999 10:40:07 -0600
Geoff Savage wrote:
> To get running on our alphas I grabbed the compiled libraries and binaries
> for the alpha from Mark Rivers web site.  Thanks :) These are for EPICS
> R3.12.  While using these I have encountered an interesting problem.  I
> receive unaligned access errors from ca_array_put().  I traced them back to
> issue_ca_array_put() in access.c.  When pdest and pvalue are incremented by
> size_of_one.  At this point dbr_long_t has a size of 4 bytes (epicsInt32).
> A long on an alpha is 8 bytes.  When the assignment is made between the two
> arrays the type of long is used.  size_of_one needs to be 8 bytes.
> I'm looking at R3.13.beta11 code.
> Any suggestions.  The problem will appear when an extra 4 bytes is written
> at the end of pdest.
The problem is the structures in db_access.h. They described the data that is
passed across the network. They assume a 32 bit architecture. CA does take care
of byte order. My guess is that it may take a lot of work to properly support 64
bit architectures.
Marty Kraimer
CA on alphas Geoff Savage
Prev: EPICS 3.13.1 and CVS schoeneburg
Next: My fix to CA on alphas Geoff Savage
Index: 1994  1995  1996  1997  1998  <1999>  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: CA on alphas Geoff Savage
Next: RE: CA on alphas Jeff Hill
