1994  1995  1996  1997  1998  <1999>  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  <1999>  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: My fix to CA on alphas
To: epics tech-talk <[email protected]>, Mark Rivers <[email protected]>
Date: Thu, 11 Feb 1999 14:36:11 -0600
I still can't build epics by moving to the base directory and typing gnumake
install.alpha.  It halts at a couple of points.
1. aitGen does not get its execute bit set.
2. /usr/shlib/libc.so has unresolved symbols when aitGen executes.  (I
changed the execute bits on aitGen by hand.)
Possible Solutions(?):
1. Add a chmod command to the makefile?
2. Change the order of the libraries on the command line?  (I'll check this
later.)
Here's what I did to get CA working.  The config files need one change.  The
nsl library is contained in the c library.
In CONFIG.Host.alpha:
#ARCH_DEP_LDLIBS = -lnsl
ARCH_DEP_LDLIBS = -lc
I moved to the libCom directory and built libCom.a.  Then I went to the ca
directory and made one minor change.
<d0ola> diff access.c access.c.orig
1915c1915
< *(dbr_long_t *)pdest = htonl (*(dbr_long_t *)pvalue);
> *(long *)pdest = htonl (*(dbr_long_t *)pvalue);
<d0ola>
I'm uncertain as to the reason behind not using the dbr_xxxx_t typedefs
here.
Then I built libca.c.  I linked in the new libraries and my program executed
with no unaligned access errors.
I now need to build the IOC software on our alpha after I finish my CA
application.  I have wrapped some basic CA functions for use in Python.
Geoff Savage
Prev: Re: CA on alphas Marty Kraimer
Next: Digital Unix gcc for 68k and PowerPC Geoff Savage
Index: 1994  1995  1996  1997  1998  <1999>  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: EPICS 3.13.1 and CVS schoeneburg
Next: RE: My fix to CA on alphas Jeff Hill
