1994  1995  1996  1997  1998  <1999>  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  <1999>  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: logging onto an ioc (rlogin,telnet)
To: [email protected], [email protected]
Date: 26 Aug 99 10:08:11 +0900
>In addition we have the problem of not being
>able to log onto the ioc console if vxWorks doesn't boot
>because of some glitch in the network when rebooting.
>Currently this requires a drive down to the
>ioc and a manual reboot. Although this doesn't happen
>often, the remote reboot cabability is important.
>We do have a request into hardware to build a
>something that will provide us with this functionality
>however this item is low on the priority list.
>What are other people using to remotely reboot or
>connect to an ioc, if vxWorks hasn't booted.
>I'm looking for a cheaper solution than purchasing
>a sun station to connect to the ioc console port.
>   - Thanks,
>        Kristi Luchini
>PS. We are using vxWorks 5.3.1
>    VME and VXI crates (w/ mv167,niCpu030 cpu's)
>    Console ports connected to a local terminal.
In KEKB, we use:
A) A conslole port of IOC is connected to the terminal server from Cisco
systems, Cisco 2500 series. Terminal server assigns IP address to each
serial port so you can telnet to these IP address directly.
B) a VME system monitor board produced by Mitsubishi Electric
coorporation(MELCO). It can monitor create voltage and has 6 digital inputs
to monitor status of the crate. It can also reset VME backplane. A micro
computer with simple command interpreter accepts a command from its serial
port.
We connect this serial port to the therminal server mentined above.
One of our programmers wrote simple Python script to reset VME crate using
this board.
Noboru Yamamoto
KEKB control group
KEK, JAPAN
Prev: mv162 vs. VPIC-616 PCI Carrier Bill Brown
Next: SENS from WRS and PowerPC; working Janousch Markus
Index: 1994  1995  1996  1997  1998  <1999>  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: logging onto an ioc (rlogin,telnet) Alan Biocca
Next: ioc consoles and resets Allan Honey
