SNMP to serial adapters, Security Policy Issues, and Watchdog Timers: I haven't had a chance to try it yet, but one suggestion I am considering is to use SNMP. Inexpensive ethernet SNMP to serial adapters are available at www.lantronix.com, and any SNMP management software could be used to connect to the crate. There are inexpensive and even free SNMP programs for most platforms. There are also handshake lines that potentially could be used to drive a reboot signal with a small hardware interface. This is similar to the other terminal servers mentioned, however they have the option to use SNMP (they can also do telnet, etc). They may be lower cost than other terminal servers. We intend to evaluate them but have not procured one yet. I was told they are quite inexpensive but this is third hand info. A quick review of the website doesn't seem to mention prices. Security Policy Issues..? More specifically, what does 'disable telnet and rlogin' mean? Not running the servers on regular hosts will not affect login to crates - to login to the crate you need only the client software which itself is no security risk. If the crate has no routes outside your secure machines (especially no default route) then rlogin or telnet attacks from outside will not be able to connect to crates due to no return route. So a security policy could be: 1) no vxworks default routes 2) no vxworks routes outside secure controls machines 3) no telnet or rlogin daemons on hosts other than vxworks 4) leave telnet/rlogin client software on hosts (this will be required in any case to connect to remote machines that still use it, the whole external world is not converting to ssh). Watchdog Timers exist on most CPU boards. We have set them up to autoreboot the crate if it fails to respond for a number of seconds. The watchdog timer is a hardware timeout-to-reset counter that must be attended periodically by software to prevent the hardware autoreboot. The timers longest timeout is generally a bit short so we used a periodic interrupt to create a lengthened version. Critical periodic code is augmented to reload the software watchdog. More than one of these can be implemented if there are several critical tasks to be monitored. The interrupt driven extender decrements and checks all critical task counters. If all of them are positive it then clears the hardware watchdog. Freezeup of any component of this causes an automatic hardware reset reboot a few seconds later. Our experience in running this for a few years was excellent - occasionally the network code would hang the system and it always repaired itself. I can't remember any occasions where we had to reboot the crate manually except to force new software versions to load. This was a cryosystem that had to run continuously for months and the software was designed to handle rebooting without ill effects on the system. This was a few versions of vxworks ago so I don't know that the code we did is of much use, and the watchdog hardware is cpu specific, so it requires a per-cpu-type library. (BEVALAC HISS CryoSystem). -- Alan K Biocca Advanced Light Source Controls At 09:31 AM 8/20/99 -0700, [email protected] wrote: Hi,
ANJ, 10 Aug 2010 |
![]() · Download · Search · IRMIS · Talk · Documents · Links · Licensing · |
