Work on porting iocCore to other operating systems besides vxWorks is progressing. The following has been accomplised Almost all of base except Channel Access, the sequencer, and hardware support has been changed to use the new osi routines rather than vxWorks specific calls. I have not touched Channel Access becuse this needs help from Jeff Hill. William Lupton is already working on a version of the sequencer that is independent of vxWorks. The hardware dependent code will be unbundled from base. Janet Anderson has modified the make system so that it works for non vxWorks IOC targets. The new system is actually easier than the old. Using the new osi independent code the example application generated by makeBaseApp has been run successfully. This was a major milestone. A document describing the iocCore port is attached. Note that to port to other systems only the libraries osiSem and osiThread need to be implemented. It should be possible to implement these using posix calls. If this is done we should be able to run iocCore on many platforms. Marty Kraimer iocCore includes the following components of epics base:
Replacements for existing vxWorks and epics componentsThe following Operating System Independent libraries replace vxWorks specific libraries.
replaces tickGet, sysClockRateGet, TSgetTimeStamp and TSgetCurrentTime. A generic and a vxWorks version is available A generic version is provided that always returns failure. a vxWorks version is provided that calls symFindByName. Replaces intLib A generic version is provided that uses a global semaphore. It can be used for winXX, Unix, Linux, etc. A vxWorks specific version is provided. Replaces rngLib. A generic version usable on all platforms is provided. A vxWorks specific version is provided. replaces semLib.h A vxWorks version is provided. No version has been written for other platforms. replaces taskLib.h A vxWorks version is provided. No version exists for other platforms. replaces wdLib.h A vxWorks version is provided. No version exists for other platforms.
This is called by code that doesnt know what to do when an error occurs. replaces symFindByName RegistryIt is not possible to expect every environment to supply an environment that makes it easy to implement vxWorks symFindByName. Instead a facility to register and find pointers to functions and structures is provided. This leaves the problem of registering everything currently located via calls to symFindByName. The following solves the problem:
Build Environment (Everyone's favorite subject :-)The build environment is different. The principal features are:
task_params.hThis will go away.
vxWorks shellIf the target is not for vxWorks, the vxWorks target shell is not available. IocInit, dbLoadRecords, etc must be called directly by main or the equivalent. The "nice" vxWorks debugging environment is not available although a nicer one using xgdb may be available.How do we run dbpr, dbgf, etc? Interrupt LevelThe vxWorks intLock/intUnlock routines are an essential part of base. For example any code, including interrupt routines, can call callbackRequest. osiInterrupt is provided to solve this problem. For operating systems like vxWorks, in which everything runs in a shared memory, multithreaded kernel environment, an osi specific version must be provided. For other operating systems, e.g. winxx, Unix, Linux, a generic version is provided. The only restriction is that kernel code MUST not call any of the osi routines.The following has been done:
A particular implementation may implement each function as desired BUT
the final result must appear to user code like the definitions in this
section. For example functions can be implemented via macros defined
in a header file that replace the generic header file.
osiClockunsigned long clockGetCurrentTick(); int clockGetRate(); int clockGetEventTime(int event_number,TS_STAMP *ts); int clockGetCurrentTime(TS_STAMP* ts);A vxWorks specific version is provided that provides exactly the same semantics as 3.13. A generic version is provided that should work on most platforms. Perhaps it should be implemented via libCom/osiTime. osiFindGlobalSymbolvoid * osiFindGlobalSymbol(const char *name);A vxWorks version is provided that calls symFindByName. It is called by the registry if a name is not found in the registry itself. A generic version is provided that always returns failure. If the generic version is used then all external symbols must be registered, See the registry for details. osiInterruptint interruptLock(); void interruptUnlock(int key); int interruptIsInterruptContext(); void interruptContextMessage(const char *message);A vxWorks specific version is provided. It maps directly to intLib calls. A generic version is provided that uses a global semaphore to lock. This version is intended for operating systems in which iocCore will run as a multithreaded process. The global semaphore is thus only global within the process. osiRingringId ringCreate(int nbytes); void ringDelete(ringId id); int ringGet(ringId id, char *value,int nbytes); int ringPut(ringId id, char *value,int nbytes); void ringFlush(ringId id); int ringFreeBytes(ringId id); int ringUsedBytes(ringId id); int ringSize(ringId id); int ringIsEmpty(ringId id); int ringIsFull(ringId id);A vxWorks specific version is provided that maps directly to rngLib calls. A generic version is provided that works on all platforms. This version is currently 1.5 times slower than the vxWorks specific version. Perhaps some clever thought can make it as fast as rngLib. osiRing has the following properties.
ringFlush should only be used if both gets and puts are locked. osiSem.htypedef void *semId; typedef enum {semTakeOK,semTakeTimeout} semTakeStatus; typedef enum {semEmpty,semFull} semInitialState; semId semBinaryCreate(int initialState); void semBinaryDestroy(semId id); void semBinaryGive(semId id); semTakeStatus semBinaryTake(semId id); void semBinaryTakeAssert(semId id); semTakeStatus semBinaryTakeTimeout(semId id, double timeOut); semTakeStatus semBinaryTakeNoWait(semId id); void semBinaryFlush(semId id); semId semMutexCreate(void); void semMutexDestroy(semId id); void semMutexGive(semId id); semTakeStatus semMutexTake(semId id); void semMutexTakeAssert(semId id); semTakeStatus semMutexTakeTimeout(semId id, double timeOut); semTakeStatus semMutexTakeNoWait(semId id); void semMutexFlush(semId id);
osiThread#define threadPriorityMax 99 #define threadPriorityMin 0 /*some generic values */ #define threadPriorityLow 10 #define threadPriorityMedium 50 #define threadPriorityHigh 90 /*some iocCore specific values */ #define threadPriorityChannelAccessClient 10 #define threadPriorityChannelAccessServer 20 #define threadPriorityScanLow 60 #define threadPriorityScanHigh 70 /* *The following functions convert to/from osi (operating system independent) * and oss (operating system specific) priority values * NOTE THAT ALL OTHER CALLS USE osi priority values */ int threadGetOsiPriorityValue(int ossPriority); int threadGetOssPriorityValue(int osiPriority); /* stack sizes for each stackSizeClass are implementation and CPU dependent */ typedef enum { threadStackSmall, threadStackMedium, threadStackBig } threadStackSizeClass; unsigned int threadGetStackSize(threadStackSizeClass size); typedef void *threadId; threadId threadCreate(const char *name, unsigned int priority, unsigned int stackSize, THREADFUNC funptr,void *parm); void threadDestroy(threadId id); void threadSuspend(threadId id); void threadResume(threadId id); int threadGetPriority(threadId id); void threadSetPriority(threadId id,int priority); void threadSetDestroySafe(threadId id); void threadSetDestroyUnsafe(threadId id); const char *threadGetName(threadId id); int threadIsEqual(threadId id1, threadId id2); int threadIsReady(threadId id); int threadIsSuspended(threadId id); void threadSleep(double seconds); threadId threadGetIdSelf(void); void threadLockContextSwitch(void); void threadUnlockContextSwitch(void); threadId threadNameToId(const char *name);Thread priorities are assigned a value from 0 to 99. A higher value means higher priority Thread stack values are handled as follows:
For posix it should be possible (I hope) to implement thread via a combination of:
osiWatchdogtypedef void *watchdogId; typedef void (*WATCHDOGFUNC)(void *parm); watchdogId watchdogCreate (); void watchdogDestroy (watchdogId id); void watchdogStart(watchdogId id, int delaySeconds,WATCHDOGFUNC funptr,*parm); void watchdogCancel(watchdogId id);A vxWorks version is provided that maps directly into mwdLib calls. I think a generic version can be implemented via base/srcf/libCom/osiTimer. This has not yet been implemented.
cantProceedvoid cantProceed(const char *errorMessage); void *callocMustSucceed(size_t count, size_t size, const char *errorMessage); void *mallocMustSucceed(size_t size, const char *errorMessage);cantProceed prints error message and then
iocCore currently uses symFindByName to dynamically bind the following:
The registration facility provides a safe and easy to use alternative to symFindByName An easy to use solution must be developed. A new implementation of initHooks is now provided. It provides a routine initHookRegister. This MUST be called by any routine that wants to be called during initialization. This has been moved to base/src/vxWorks. Thus for now it is only supported on vxWorks This has been moved to base/src/vxWorks. Thus for now it is only supported on vxWorks This was rewritten to be independent of vxWorks. Moved to base/src/vxWorks. Thus for now it is only supported on vxWorks. Either moved to base/src/vxWorks. or unbundled from base. OverviewThe basic idea is to provide a registration facility. Any storage meant to be "globally" accessable must be registered before it can be accessed by other code.A perl script is provided that reads the xxxApp.dbd file and produces a c file containing a routine registerRecordDeviceDriver, which registers all record/device/driver support defined in the xxxApp.dbd file. registryThis is the code which does the work. Each different set of things to register must have it's own unique ID. Everything to be registered is stored in the same gpHash table.int registryAdd(void *registryID,const char *name,void *data); void *registryFind(void *registryID,const char *name);int registrySetTableSize(int size); void registryFree(); int registryDump(void); Routine registrySetTableSize is provided in case the default hash table size (1024 entries) is not sufficient. registryRecordType.hSome features:typedef int (*computeSizeOffset)(dbRecordType *pdbRecordType); typedef struct recordTypeLocation { struct rset *prset; computeSizeOffset sizeOffset; }recordTypeLocation; int registryRecordTypeAdd(const char *name,recordTypeLocation *prtl); recordTypeLocation *registryRecordTypeFind(const char *name);
registryDeviceSupportThis provides access to the device support entry table.int registryDeviceSupportAdd(const char *name,struct dset *pdset) struct dset *registryDeviceSupportFind(const char *name); registryDriverSupportThis provides access to the driver support entry table.int registryDriverSupportAdd(const char *name,struct drvet *pdrvet); struct drvet *registryDriverSupportFind(const char *name); /* The following function is generated by registerRecordDeviceDriver/pl */ int registerRecordDeviceDriver(DBBASE *pdbbase); registerRecordDeviceDriver.plThis is the perl script which creates a c source file that registers record/device/driver support. Make rules are provided that
registerRecordDeviceDriver.cA version of this is provided for vxWorks. This version makes it unnecessary to use registerRecordDeviceDriver.pl or register other external names. Thus for vxWorks everything can work almost exactly like it did in release 3.13.x
ANJ, 10 Aug 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
