1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: Channel Archiving
To: Jeff Hill <[email protected]>
Cc: [email protected]
Date: Thu, 18 Nov 1999 14:44:51 -0500
Jeff Hill wrote:
> Chris,
> My only comment is that similar functionality is planned in CA V4
> (ala my paper/poster from ICALEPCS 99 and my talk at the last
> two collaboration meetings), and so there is some potential for
> redundant code in the IOC. Perhaps there is some way that we can
> combine our efforts?
  Certainly!  I hadn't realized that you were actually working
on this already, and thought that it was a "gee it would be nice
if someone would do this" sort of deal.  As I am just starting,
perhaps we should discuss our ideas and try to synthesize some-
thing from them.  Because this work is precipitated by course-
related research, my immediate goals are a precise understanding
of the problem and a formulation of the solution, with the
implementation being secondary; once I've arrived at this under-
standing, though, the implementation should follow in a fairly
straightforward fashion (really, I have no naive expectation that
it will be *easy*)...
Chris
> Jeff
> > -----Original Message-----
> > From: [email protected] [mailto:[email protected]]
> > Sent: Wednesday, November 17, 1999 5:43 PM
> > Hi all,
> >   [the following is fairly long and perhaps tedious,
> >    so here's the executive summary]
> >   I'm working on a data logger which will run on an
> >   ioc, compress channel data in real-time, and stream
> >   it over the network to a spooler.  I hope that the
> >   resulting system can be generally useful to other
> >   sites, and so need some small amount of information
> >   and/or comments.
> >   [end executive summary, but there's some more good
> >    stuff at the bottom]
> >   (1) What is the fastest rate at which people want to
> >       log data from an ioc?
> >   (2) How much of this data is there?
> >   My preliminary investigation of how data behaves on
> > the ioc's here at JLAB indicates that, if we consider
> > each byte which comprises a signal's value as an
> > independent quantity, the probability that any particular
> > one of these will change in a ten minute period ranges
> > between 0.005 and 0.05 (this is sampling at 1 hz).
> > Futhermore, when a byte does change, it does so in a
> > remarkably structured manner  (see
> > http://www.sura.org/~larrieu/Info.html).
> > From an information theory standpoint, this means that
> >   (1) the observation that a signal has not changed
> >       carries very little information and can therefore
> >       be conveyed with minimal overhead.
> >   (2) when a byte does change, it will probably change
> >       to one of the predictable values, so this too can
> >       be encoded using very low bit rates.
> >   (3) when a byte changes to an unlikely value, then
> >       we need more bits to indicate such, though this
> >       happens relatively infrequently.
> >   Of course, when you know that a certain byte belongs
> > to a certain signal, then you know more about its
> > behavior over time.  By monitoring this behavior we
> > can build a fairly accurate statistical model of it
> > so that we can further reduce the amount of information
> > required to indicate a change in value.
> >   The whole point here is that I believe we can achieve
> > dramatic results by compressing the channel data on the
> > ioc, then sending the result over the wire to a simple
> > spooling process.
> >   My intent is to:
> >   (1) implement this logging system
> >   (2) implement a client library for accessing the logged
> >       data, using Kay's C++ API.
> >   (3) build a new data extraction tool using (2)
> >   The benefits should be:
> >   (1) ability to store more information with less data
> >   (2) significantly reduced network traffic
> >   (3) circumvent CA size limit
> >   (4) compatible high-level interface, facilitating
> >       sharing of tools between participating labs.
> >   Trade-offs:
> >   (1) increased memory requirements on ioc
> >   (2) possibly significant CPU time on ioc
> >   (3) increased access time to archived data (decompress)
> >   (4) annoyance: another archiver?!
> > Chris
> > Christopher A. Larrieu
> > Jefferson Laboratory
> > (757) 269-5097
(757) 269-5097
RE: Channel Archiving Jeff Hill
Prev: R3.13.1 RISC Arch IOC BUG Report (assertion failure in dbEvent.c) Jeff Hill
Next: Re: capfast symbol for transform and ANL motor record? Benjamin Franksen
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: RE: Channel Archiving Jeff Hill
Next: Re: Channel Archiving Garrett D. Rinehart
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
