Jeff,
I'm not sure if this works into the same problems that you have with the
10/100 Ethernet you are using but, when loading the databases I get some
strange messages that look like the ethernet is being reset.
cd startup
value = 0 = 0x0
dbLoadDatabase("../../dbd/daqApp.dbd")
value = 0 = 0x0
dbLoadDatabase("../../dbd/RunfileApp.dbd")
value = 0 = 0x0
dbLoadRecords ("../../db/roc_slave.db","inst=hrcs2:ROC:,inst2=hrcs1:ROC:")
value = 0 = 0x0
dbLoadRecords("../../db/instsetup.db","USER=hammonds,INST=hrcs2")
value = 0 = 0x0
dbLoadRecords("../../db/hrcs2_tof.db")
interrupt:
ei0: reset
value = 0 = 0x0
note the two lines above the last value statement. This line usually
appears here but will sometimes occur elsewhere. This is a fairly good size
database so it's likely that probablity states that I see it here.
John
RE: EPICS 3.13.2 and vxWorks 5.4 Jeff Hill
Re: alarm handler question William Lupton
<2000>
EPICS and Gemini Stephen Goodsell
<2000>
