1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: VxWorks global variable support extension proposal
To: [email protected]
Date: Thu, 13 Jan 2000 10:18:05 -1000
Dear all,
We realized yesterday that the VxWorks global variable device support
does not support selection of an individual bit (for bi/bo) or a range
of bits (for mbbi/mbbo) from the underlying global variable. Device
support for bi/bo simply copies a 'short' into .VAL and for mbbi/mbbo
copies a 'long'.
This hasn't been in an issue for us in past applications but now we have
a case where a device is mapping extensive data structures, including
some words where we would like to map individual bits on to bi/bo or
ranges of bits on to mbbi/mbbo, into VxWorks memory. We would like to
use the global variable device support to access these data structures.
Here is a proposal:
1. extend the VxWorks global variable device support (INST_IO version) so
   the link string, which is currently of the form
   [ "*" ] name [ "[" index "]" ]
   is of the form
   [ "*" ] name [ "[" index "]" ] [ keyword "=" value ] ...
   where the keyword/value pairs carry extra configuration information
2. keyword names would be case-independent and abbreviable (ambiguous
   abbreviations would refer to that keyword which was first supported;
   this guarantees backwards compatibility); initially, two keywords
   would be supported
   name		value				default
   start	bit number of lsb (0-31)	-1
   type		type of underlying var.		as at present (*)
   "start" specifies the same information that the "S" field does (by
   convention) for VME_IO; the default of -1 means that the entire
   variable is copied (as at present; needed for backwards compatibility)
   "type" specifies the type of the underlying global variable; currently
   this is implied by the record type; it would be particularly useful to
   be able to specify that a bi/bo comes from a long, which is not possible
   at present; the type names are the C names (with no support for "unsigned")
   and are case-independent and abbreviable
3. white space is permitted everywhere (and is ignored, as at present)
4. note that bo/mbbo support may (strictly) require use of a semaphore to
   cover the case where several records which access the same word are
   processing concurrently (I recall an earlier discussion that resulted
   in the use of intLock()/intUnlock(); one could add taskLock()/taskUnlock()
   instead of a semaphore?)
Here are some examples:
assume that ssss is a 'short' global variable whose value is 0x1234 and
llll is a 'long' global variable whose value is 0x12345678
1. bi: ssss s=4
   VAL field is set to ssss's bit 4 (1)
2. bi: llll s=31 t=long
   VAL field is set to llll's bit 31 (0)
3. mbbo: ssss s=8 t=short
   NOBT bits of ssss, starting at bit 8, are set to VAL (VAL masked to NOBT
   bits and shifted left by 8 bits)
Comments?
William
Re: VxWorks global variable support extension proposal Carl Lionberger
Re: VxWorks global variable support extension proposal Andrew Johnson
Prev: DL-PC board question john sinclair
Next: RE: DL-PC board question Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: DL-PC board question Jeff Hill
Next: Re: VxWorks global variable support extension proposal Carl Lionberger
