1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: NULL record Name on IOC
To: <[email protected]>, <[email protected]>
Date: Thu, 13 Jan 2000 17:03:14 -0700
Noburo,
> Eventually we found a cause of phenomena. One of reasons of this trouble
> is a record with NULL string as its name. All three of IOCs were loaded
> a NULL named EPICS record. These records did not cause any problem,
> until I run a CA client program which search for a NULL named record!
> dbLoadRecords commands in EPICS R3.13.1 accepts a NULL named record
> without a error message.
> CA library on WS also accepts NULL string as a record name.
There appears to be code in the CA client library which
checks the length of the channel name string. This code is from
R3.13.2 and it is possible that R3.13.1 is different.
	/* Put some reasonable limit on user supplied string size */
	strcnt = strlen(name_str) + 1;
	if (strcnt > MAX_UDP-sizeof(caHdr))
		return ECA_STRTOBIG;
	if (strcnt == 1)
		return ECA_EMPTYSTR;
There is not at this time any code in the client library that verifies
that the channel name string pointer isn't NULL, but I have added this check
to EPICS R3.14.
Jeff
NULL record Name on IOC Noboru Yamamoto
Prev: Re: VxWorks global variable support extension proposal Andrew Johnson
Next: Monitors for the STAT field Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: NULL record Name on IOC Noboru Yamamoto
Next: Is there a "PerlCa" out there? Carl Lionberger
