1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: VXI Kinetic Systems V151 cpu - PowerPC
To: [email protected]
Cc: [email protected]
Date: Tue, 07 Mar 2000 16:35:12 -0600
[email protected] wrote:
> 1) missing lib vix functions such as SetMODID
I can't help with that one, but...
> 2) missing or renamed unsolicited interrupt handlers
>    excStub and excIntStub.
>   (from  devlib.c defaultHandlerNames[])
> 3) Is anything else tobe used in place of intHandlerCreate()
>    for powerPC...or is this handled in some other way?
These two are known about, what version of EPICS are you using - I think
3.13.2 has sections of veclist.c #if...#endif'ed out for PPC CPUs.  Unless
your BSP provides some code for the vxWorks intVecGet() routine the EPICS
veclist output is of no use anyway (all zeros IIRC). I have code for the
mv2700 board that makes it somewhat more useful.
You also want to be careful about multiple interrupts on the same vector -
your BSP may allow several intConnect()s to the same vector number and
call the ISRs in turn.
> 4) sysBusTas() seems to be different for the PowerPC but
>    I can't find out what the difference is in the WindRiver
>    manuals. Does anyone know how this function differs for the
>    PPC?  When calling sysBusTas() from the allenBradley driver
>    the following occurs:
sysBusTas() on your PPC CPU may not be implemented in a way that is
compatible with the 68k TAS instruction, as the PPC can't generate
Read-Modify-Write cycles itself (it provides an alternative method for
multi-CPU atomic operations that involves bus snooping). Does the KSCorp
board use a Tundra Universe II chip to interface to the VME/VXI bus?  If
not then it may be impossible to control an AB scanner module from this
board; you have to be able to generate a true VMEbus Read-Modify-Write
cycle to talk to the AB cards.  I wrote some code which makes the Universe
II chip do this for the APS version of the mv2700 BSP.  If you don't have
a Universe chip you'll have to find out more about the VME interface
hardware.
- Andrew
Complexity comes for free, Simplicity you have to work for.
VXI Kinetic Systems V151 cpu - PowerPC luchini
Prev: VXI Kinetic Systems V151 cpu - PowerPC luchini
Next: Fatal GDD deficiencies Ralph . Lange
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
