> Dear Ned Arnold
> Maybe this should have gone to the list, but the answer is
> probably pretty obvious.
> > Old style drivers have the starting address, interrupt vectors,
> > max number of cards, etc stored in include/module_types.h .
> I want to use a bunch of XYCOM XVME-240's in a single crate. The limit on
> the number of these modules, as specified in include/module_types.h, is 2.
> If I want to increase that to 10, is it just a matter of changing the
> value to 10 in include/module_types.h and recompiling?
> thanks for any help,
> Steve Pate
You could do it that way, but everytime you get a new EPICS release you
would have to remember to change it.
The scheme that is recommended to change items defined in module_types.h is :
1) Copy the file base/drv/old/module_types.c to your application area src
directory.
2) Edit module_types.c to delete things you don't want to change and edit
those that you do.
3) Add module_types.o into your xxxAppLib (Makefile.Vx)
4) In the startup file, after the "ld < xxxAppLib", exceute the function
module_types. e.g.
cd appbin (example is for 3.13.2)
ld < iocCore
ld < seq
ld < xxxAppLib
module_types
This will over-write the default values before the drivers begin their
initialization.
Ned
Re: IOC Performance numbers Marty Kraimer
Re: INP field for generic GPIB record Allan Honey
<2000>
Re: INP field for generic GPIB record Ned Arnold
<2000>
