1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: putAcks
To: tech-talk <[email protected]>
Date: Tue, 16 May 2000 15:11:41 -0500
I'm trying to understand the internals of alarm acknowledgement.  Here's
my interpretation of putAcks().
static long putAcks(paddr,pbuffer,nRequest,no_elements,offset)
DBADDR  *paddr;
unsigned short  *pbuffer;
long            nRequest;
long            no_elements;
long            offset;
    dbCommon *precord=(dbCommon *)(paddr->precord);
    if(*pbuffer >= precord->acks) {
        precord->acks = 0;
        db_post_events(precord,NULL,DBE_ALARM);
        db_post_events(precord,&precord->acks,DBE_VALUE|DBE_ALARM);
    return(0);
1. Only do anything when the acknowledge severity is higher than or
equal to the currently unacknowledged severity.
Assuming this condition is met then
2.  Reset the unacknowledge severity.
3. ???Send an alarm monitor to all clients monitoring at least one field
in this record.???
4. Send a monitor to all clients monitoring the ACKS field value or
alarm in this record.
I'm uncertain as to the purpose of step 3.  Would someone please
explain.
Thanks
Geoff
Re: putAcks Marty Kraimer
Prev: Re: Build static libraries on WinNT Vladimir Sirotenko
Next: Re: putAcks Marty Kraimer
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Capfast for Linux? William Lupton
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
