Grahm,
You might also try reconfiguring vxWorks to allow
the IP kernel to expand its internal pool.
In Tornado II this can be configured in their workspace
GUI by clicking the vxWorks tab and then following this
hierarchy:
network components
basic network components initialization
Next, double click "network buffer initializations" and then
select the "params" tab.
Jeff
> -----Original Message-----
> From: Graham Waters [mailto:[email protected]]
> Sent: Tuesday, October 10, 2000 4:53 PM
> To: [email protected]
> Subject: socket creation errors
> I am in the process of porting our epics applications from
> epics R3.13.1 under vxWorks 5.3 to epics R3.13.3 under vxWorks 5.4.
> Generally thinks went quit well with no problems building the
> epics release. However I have one application involving TCP/IP
> connections in device support. I create driver instances and a
> few sockets prior to calling iocInit without error messages.
> After iocInit generally something like the following happens. Its
> as though I gobble up all available space for socket ID's.
> interrupt
> eio: reset
> socket create failed: errno = 0x37 (CA_TCP): CAS: Socket creation error
> ../repeater.c: Unable to create repeater socket because 55="errno =
> 0x37"
> CAS: casts socket creation error
> filename="../taskwd.c" line number=175
> CA_TCP suspended
> CAT_UDP suspends
> error number 55 seems to be "No buffer space available"
> The problem goes away if,
> 1) I reduce the number of epics devices using sockets
> (yes I did increase the value of "NUM_FILES")
> 2) Build a kernel with all WDB tasks excluded
> I have seen references to "interrupt, eio: reset" in tech-talk"
> whatever causes that message seems to be benign.
> Does any of this mean anything or sound familiar to anybody.
> |Graham Waters, Control System Eng phone: (604)-222-1047 |
> |TRIUMF --- University of B.C, Fax: (604)-222-7307 |
> |Vancouver, BC, Canada e-mail: [email protected] |
> |http://edevel9pc.triumf.ca/homepage/graham01.html |
> For every expert there is an equal and opposite expert
> - Arthur C Clark
- Re: socket creation errors Graham Waters
- socket creation errors Graham Waters
RE: socket creation errors Mark Rivers
Keithley 7002/2010 data aquisition Mathew Rippa
<2000>
<2000>
