1994  1995  1996  1997  1998  1999  2000  <2001>  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  <2001>  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: NFS file IO problem
To: <[email protected]>
Date: Wed, 10 Jan 2001 12:10:25 -1000
Hello -
I am having NFS file IO problems on my EPICS IOC. I am curious if any of you
have encountered anything similar.
I want to read a file from an NFS mounted disk and use data to post to EPICS
records on the IOC. The time to read the file is quite long, and seems to vary
anywhere from 5 or 6 seconds up to 40 or 50 seconds. When I try the same file
access without having EPICS running, the file read happens very quickly (< 1
sec). Although the file is large (~600k), 40 or 50 seconds to load is long
enough to cause problems for my application.
I am using an mv2304 running EPICS R13.0Beta12.
Any advice or help you can give me will be greatly appreciated. I searched the
tech-talk archives regarding this issue, but did not find anything directly
related.
Erik
o----------------------------------------------------------------o
| Erik M. Johansson                      |                       |
| Project Engineer                       | Phone: (925) 424-4134 |
| Imaging, Detection, and Sensors Group  | Fax:   (925) 422-1796 |
| Lawrence Livermore National Laboratory | email: [email protected] |
| PO Box 808, L-258, Livermore, CA 94551 |                       |
Prev: FREE CapFast in January, 2001 Dr. Chong Lee
Next: channel access dicsconnects Kevin Tsubota
Index: 1994  1995  1996  1997  1998  1999  2000  <2001>  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
