1994  1995  1996  1997  1998  1999  2000  <2001>  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  <2001>  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: channel access dicsconnects
To: [email protected]
Date: Fri, 12 Jan 2001 17:33:01 -1000 (HST)
We two MV2307s in seperate VME crates running EPICS.  In one of the
crates I have to EPICS sequencers that monitor channels on the
other crate.
Periodically this crate will lose its channel access connection
to the other and never reconnect, as if the crate that its connecting
to was powered off.  However this is not the case. Both crates are
up and running and the only problem is that the first crate got
disconnected from the second and never reconnects.
"caget" on the disconnected channels work fine.
Does anyone have any clues what could be causing these disconnects
and why the sequencers won't reconnect?  We are running VxWorks 5.3.1
and EPICS R3.13.0Beta12.
Thank you.
Kevin Tsubota
RE: channel access dicsconnects Jeff Hill
Prev: NFS file IO problem Erik Johansson
Next: device support for IK340 Peter Mueller
Index: 1994  1995  1996  1997  1998  1999  2000  <2001>  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: channel access dicsconnects Jeff Hill
