1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: RE: EPICS runtime problems on Motorola mv162-P242E CPUs
To: "'[email protected] '" <[email protected]>, Mark Rivers <[email protected]>, "'EPICS TechTalk '" <[email protected]>
Date: Thu, 8 Feb 2001 08:00:38 -0600
> we've tested the MVME162-P344E (wich should replace the old MVME162-
> 532a)together with EPICS.
> The good news is that the board was compatible to the old one regarding
> the BSP.
> The bad news is that we encountered interrupt problems which caused a
> reboot of the IOC after some ours.
> I talked with my distributor and he told me that the first series of the
> Petra ASCISs has definitively BUGs regarding interrupts. Therefore
> Motorola has replaced the Petra ASIC with a new one. As far as I know
> the boards with the new ASIC habe the letter 'A' after the 'P' . The new
> MVME162-P344E is now called MVME162-PA344E.
I just received an MVME162-P344E.  I have an unrelated question regarding
how to program vxWorks into the Flash.  I left the board in its factory
configuration of jumpers and switches and tried the example they give in the
manual of programming the Bug debugger into the Flash.  I am working from
memory now, but I think the command was
pflash 8000000:800000 FFA00000
Bug printed out the addresses which would be programmed and they looked
correct.  However, it then gave an error something like:
pflash error in address range
I am sure I typed exactly what was in the manual.  I also tried programming
vxWorks from RAM to Flash using exactly the instructions which used to work
on the old MVME162.  I got the same error.
What do I need to change from the factory default to allow Flash progamming
to work?
Mark Rivers
RE: EPICS runtime problems on Motorola mv162-P242E CPUs Joachim . Rahn
Prev: Re: EPICS runtime problems on Motorola mv162-P242E CPUs Joachim . Rahn
Next: RE: EPICS runtime problems on Motorola mv162-P242E CPUs Joachim . Rahn
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
