1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Problems with GSOctalRS232
To: <[email protected]>
Date: Wed, 25 Apr 2001 15:17:39 +0800
There are some vacuum devices using RS232 and RS485 interface in our project.
So we select a solution consisting of MVME2302, VIPC616, and GSOctal IP module. We also download the Ipac2.2 package.
But we failed set up this device driver from within a vxWorks startup script. The information is as follows:
tyGSOctalDrv 4
allocating 4 structures of 2056 bytes
value = 0 = 0x0
ipacAddCarrier &vipc616,"0x6000"
value = 0 = 0x0
MODO = tyGSOctalModuleInit("GSIP_OCTAL232",0x80,0,0)
0x1bef5d0 (tShell): tyGSOctalModuleInit: No memory allocated for carrier new symbol "0 slot MODO0" added to symbol table.
MODO = 0x1bd5ef8: value = -1 = 0xffffffff = tyGSOctalModules + 0xfe4104cf
PORT00 = tyGSOctalDevCreate("/tyGS/0/0",MODO,0,512,512)
new symbol "PORT00" added to symbol table.
PORT00 = 0x1bd5eb0: value = -1 = 0xffffffff = tyGSOctalModules + 0xfe4104cf
It looks like that "tyGSOctalModuleInit" routine return with ERROR.
How can I do?
TIA
Yongbin Leng
[email protected]
Re: Problems with GSOctalRS232 Andrew Johnson
Prev: longoutRecord Bug Eric Bjorklund
Next: Re: longoutRecord Bug Andy Foster
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: longoutRecord Bug Marty Kraimer
Next: Re: Problems with GSOctalRS232 Andrew Johnson
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
