Hi Eric,
Yes, I noticed this too and have "spoken" (over E-mail) with
Marty about it.
There are other records which exhibit the same feature, namely:
dfanout, stringout, steppermotor.
All have code similar to the longout with respect to the DOL
link. What I did was changed the longout and others to be like
this:
if (!plongout->pact) {
if( (plongout->dol.type != CONSTANT) && (plongout->omsl ==
CLOSED_LOOP)) {
status = dbGetLink(&(plongout->dol),DBR_LONG,
&value,0,0);
if (plongout->dol.type!=CONSTANT &&
RTN_SUCCESS(status))
plongout->udf=FALSE;
else {
value = plongout->val;
if (!status) convert(plongout,value);
Then for a CONSTANT DOL type, the value gets initialized as it does
in an ao record.
Cheers,
Andy
Eric Bjorklund wrote:
> I appear to have discovered a bug in longoutRecord.c under R3.13.4 which
> probably dates back to R3.13.3, when the drvh & drvl fields were added.
> The manifestation is that a longout record with OMSL in closed_loop and
> a constant value in the DOL link, will end up with an arbitrary value
> in VAL when the record is processed.
> The culpret is in the following code from the "process" routine:
> if (plongout->omsl == CLOSED_LOOP) {
> &value,0,0);
> if (plongout->dol.type!=CONSTANT && RTN_SUCCESS(status))
> else {
> If dol.type is CONSTANT, dbGetLink does not fetch the link value, and so
> the variable "value" is never initialized.
> The fix, I've implemented for now is to initialize "value" in its declaration
> at the begining of the process routine, i.e:
> long value=plongout->val;
> This restores the longout record to its previous behavior -- which is not
> the same as, for example, an ao record with the similar setup since it
> allows you to change the value by writing to the VAL field. For that, however,
> we'd probably have to add another field to longout (such as the ao's PVAL
> field).
> Eric Bjorklund
> LANSCE-6 Controls
> Los Alamos Neutron Scattering Center.
> [email protected]
Observatory Sciences Limited Email: [email protected]
William James House Tel: 44 - (0)1223 - 508257
Cowley Road Fax: 44 - (0)1223 - 508258
Cambridge, CB4 0WX, UK http://www.observatorysciences.co.uk
- Re: longoutRecord Bug Marty Kraimer
- longoutRecord Bug Eric Bjorklund
Problems with GSOctalRS232 Leng Yongbin
<2001>
<2001>
