1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: RE: Newbie trying to move steppers in a CA client (fwd)
To: "'Chris Jacobsen '" <[email protected]>
Cc: "'[email protected]'" <[email protected]>
Date: Wed, 9 May 2001 07:50:07 -0500
Chris,
First, I don't think the NSLS is using the "steppermotor" record, they are
using the "motor" record, written by Tim Mooney from APS.  This is what we
use at the APS, and also at X-26 and X-17C at the NSLS.  The "motor" record
has many more features than the "steppermotor" record, and the OMS device
support has had a lot of work done on it.
Second, are you using the raw "ca" library from EPICS base?  If so, then it
is much more work than you want, since you need to worry about callbacks
when things change, etc.  I would recommend using the "ezca" library, which
is very simple for most applications.
You don't want to use the ".h" file, you just need to know the names of the
relavent fields.  In the motor record these are motor.VELO for the velocity,
motor.MRES for the resolution, motor.TWV for the tweak value, etc.  There is
Web documentation of the motor record and its fields.
If it would help I have an IDL class library for the EPICS motor record, so
you can do things like:
x = obj_new('EPICS_MOTOR', 'X1A:x_stage')
x->move, 100, /relative
x->set_velocity, 2.5
To know if you are using the "motor" or "steppermotor" records do the
following:
- Get a connection to the VME crate console, either via serial port or
telnet.
- Type the command
  dbl "motor"
  If you are running the motor record it will give a list of all the motors.
Cheers,
Re: Newbie trying to move steppers in a CA client (fwd) Benjamin Franksen
Prev: Newbie trying to move steppers in a CA client Chris Jacobsen
Next: Re: Newbie trying to move steppers in a CA client Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: Newbie trying to move steppers in a CA client Tim Mooney
Next: Re: Newbie trying to move steppers in a CA client (fwd) Benjamin Franksen
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
