1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: Newbie trying to move steppers in a CA client (fwd)
To: [email protected]
Date: Mon, 14 May 2001 12:29:38 +0200
Mark Rivers wrote:
> To know if you are using the "motor" or "steppermotor" records do the
> following:
> - Get a connection to the VME crate console, either via serial port or
> telnet.
> - Type the command
>   dbl "motor"
Since (i believe) base release 3.13.2, there is a "pseudo"-field named
"RTYP", that you can directly query by CA. It contains the record type
name.
Ben
RE: Newbie trying to move steppers in a CA client (fwd) Mark Rivers
Prev: Help about RAMP shen guobao
Next: devLib.c vs devLibVxWorks.c Brian McAllister
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: RE: Newbie trying to move steppers in a CA client (fwd) Mark Rivers
Next: block output record Geoff Savage
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
