1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Apropos making fields configurable
To: Bob Dalesio <[email protected]>
Cc: Benjamin Franksen <[email protected]>, EPICS Techtalk <[email protected]>
Date: Mon, 06 Aug 2001 10:38:36 -0500
While I was away on vacation, Bob Dalesio wrote:
> Also, the LINR field is an enum. Having it be an enum for
> anything it finds and an arbitrary string if it is not
> located, is not supported. When we connect to CA, the field
> primatives cannot be mixed.
LINR might be converted to a string field, which would allow the desired
behaviour (and permit the addition of new breakpoint tables at run-time).
Another problem with the enum is that it really should be dynamic
according to the breakpoint tables actually loaded into the IOC, but it
isn't.  However switching to a string will probably break some existing
databases and displays, so I expect it to be rejected.
- Andrew
The world is such a cheerful place when viewed from upside-down
It makes a rise of every fall, a smile of every frown
Re: Apropos making fields configurable Benjamin Franksen
Re: Apropos making fields configurable Bob Dalesio
Prev: RE: DM/EDD and Redhat Linux Ernest L. Williams Jr.
Next: Re: Apropos making fields configurable Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Apropos making fields configurable Bob Dalesio
