1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: VxWorks kernel configuration for GPIB
To: Robert Willson <[email protected]>
Cc: tech talk <[email protected]>
Date: Tue, 07 Aug 2001 13:42:25 -0500
Robert Willson wrote:
> Is there a specific VxWorks kernel configuration that is required to use
> the GPIB driver in EPICS?  I am asking specifically about changing the
> files configAll.h and sysLib.h, but my problem now is that all GPIB
> requests return a "GPIB TIMEOUT (while talking)" unless I use a specific
> kernel, and unfortunately I do not have information about what options
> were used to compile the kernel.
What GPIB interface are you using?  If it's the NI-1014 then your BSP
needs to have sysA24Malloc() defined for the particular CPU - the 1014 can
only do DMA into the VME A24 space, but for boards with more than 8MB of
RAM the default vxWorks mappings don't make RAM available in A24.  I can
provide the necessary sysLib.c source on request for the mv162, mv167,
mv172, mv2100 and mv2700 CPUs, although I can't guarantee that it will
work straight off as we have other changes in our BSPs so you might have
to do some integration work.
- Andrew
The world is such a cheerful place when viewed from upside-down
It makes a rise of every fall, a smile of every frown
VxWorks kernel configuration for GPIB Robert Willson
Prev: VxWorks kernel configuration for GPIB Robert Willson
Next: Re: mvme162lx bootrom Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: Channel Archiver john sinclair
