1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: CA and unsigned types
To: [email protected]
Cc: [email protected]
Date: Tue, 14 Aug 2001 18:41:29 -0400
>>> On 11/12/1996 at 16:55:17 GMT, Jeff Hill wrote:
  > The unsigned integer types used internally in the database do not
  > currently exist in the ca client API. To get around this problem EPICS
  > ioc core informs clients attached to "unsigned int" fields that the
  > native type is "float". This promotion to a larger type guards against
  > the loss of information during type conversions.
  > Johnny Tang at CEBAF has recommended that "unsigned char" and "unsigned
  > short" should map to a 32 bit integer external type (without loss of
  > information). This change is planned for the next release of EPICS.
Is this behaviour actually documented anywhere other than the Tech-Talk
archives ?
I found no mention either in the Record Reference Manual or the App.
Developer's Guide.
Was the effect on large arrays considered ?  In my case, this caused a
waveform record of type USHORT and size 6000 to be unusable.
Is there a plan to implement these types in CA ?
Brian McAllister                    Controls Programmer/Beam Physicist
[email protected]                        MIT-Bates Linear Accelerator
(617) 253-9537                                           Middleton, MA
Re: CA and unsigned types Brian McAllister
RE: CA and unsigned types Jeff Hill
Re: CA and unsigned types Marty Kraimer
Prev: Re: RAWF, RAWL Andrew Johnson
Next: Re: CA and unsigned types Brian McAllister
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: [Fwd: vxWorks, other ops] Rolf Keitel
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
