1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: CA and unsigned types
To: [email protected]
Cc: [email protected], [email protected]
Date: Wed, 15 Aug 2001 08:49:13 -0500
Brian McAllister wrote:
> >>> On 11/12/1996 at 16:55:17 GMT, Jeff Hill wrote:
>   > The unsigned integer types used internally in the database do not
>   > currently exist in the ca client API. To get around this problem EPICS
>   > ioc core informs clients attached to "unsigned int" fields that the
>   > native type is "float". This promotion to a larger type guards against
>   > the loss of information during type conversions.
>   > Johnny Tang at CEBAF has recommended that "unsigned char" and "unsigned
>   > short" should map to a 32 bit integer external type (without loss of
>   > information). This change is planned for the next release of EPICS.
> Is this behaviour actually documented anywhere other than the Tech-Talk
> archives ?
> I found no mention either in the Record Reference Manual or the App.
> Developer's Guide.
> Was the effect on large arrays considered ?  In my case, this caused a
> waveform record of type USHORT and size 6000 to be unusable.
I am not aware of any plans to change the current mappings which are:
epicsShareDef unsigned short dbDBRnewToDBRold[newDBR_ENUM+1] = {
        0, /*DBR_STRING to DBR_STRING*/
        4, /*DBR_CHAR to DBR_CHAR*/
        4, /*DBR_UCHAR to DBR_CHAR*/
        1, /*DBR_SHORT to DBR_SHORT*/
        5, /*DBR_USHORT to DBR_LONG*/
        5, /*DBR_LONG to DBR_LONG*/
        6, /*DBR_ULONG to DBR_DOUBLE*/
        2, /*DBR_FLOAT to DBR_FLOAT*/
        6, /*DBR_DOUBLE to DBR_DOUBLE*/
        3, /*DBR_ENUM to DBR_ENUM*/
These mapping have been used for several years and I dont think they should be
changed because any change could inpact existing applications.
No matter what mapping is chosen, it will not satisfy all requirements. In
hindsight, I think we should have used the same semantics that the C compiler
uses. If we had mapped DBR_USHORT to DBR_SHORT and DBR_ULONG to DBR_LONG we
would have the same semantics. It is too late now to make these changes because
they may impact existing applications.
Note that when the next generation CA interface appears it will allow all the
date types dbAccess currently supports.
Marty Kraimer
Re: CA and unsigned types Brian McAllister
Prev: Re: RAWF, RAWL Benjamin Franksen
Next: Re: CA and unsigned types Brian McAllister
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: CA and unsigned types Chip Watson
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
