1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: alarm handler confusion (and solution)
To: Maren Purves <[email protected]>
Cc: [email protected]
Date: Thu, 30 Aug 2001 10:18:30 +0200
  > yup. did too, ours was dated of some time in 1997.
  > Found quite a few other improvements too.
Good for you...
  > Question: I put
  > alh -filter a -s <config file>
  > and it runs without beeping ok. The way I understand the documentation
  > the "- filter a" should make the blinking of alarms go away when
  > the alarms are no longer active. Am I understanding this wrong or
  > did I write the command line wrong? This would be nice to have
  > because we run several alarm handlers and it would be nice to just
  > look at one screen and know if there are alarms that are still
  > active.
Hmm ... well ... the "-filter" option actually does something different:
It is intended for alhs that get started dynamically (i.e. from medm2k
panels with a "show errors" button). Starting these with the cmdline
options "-mainwindow -filter a" gets you an open alarm handler window
that just shows the active alarms. Background: some of our complex
devices (RF-PLCs) have hundreds of error bits - and noone wants to
scroll down pages of ok-channels to find the few bits that are active.
You should look at the A and T bits of the channel mask instead. Setting
the T bit frees the operator from acknowledging an alarm that went away
meanwhile, channels with an A bit don't need acknowledgement at all. You
will have to create different configs for the "overview" and the
"operator" alhs, though. (Or reconfigure manually after start.)
Hope this helps,
Ralph
alarm handler confusion (and solution) Maren Purves
Re: alarm handler confusion (and solution) Ralph . Lange
Re: alarm handler confusion (and solution) Maren Purves
Prev: Weird file access problem with vxWorks Mark Rivers
Next: Re: Weird file access problem with vxWorks Ernest L. Williams Jr.
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: alarm handler confusion (and solution) Maren Purves
Next: Re: alarm handler confusion (and solution) Janet Anderson
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
