1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: CA package(R3-14) on VxWorks/PPC604
To: Pierre-André Amaudruz <[email protected]>, EPICS tech-talk <[email protected]>
Date: Mon, 17 Sep 2001 15:48:10 -0500
Pierre-André Amaudruz wrote:
> -> ld < ComLibrary.o
> Undefined symbol: sntpcTimeGet (binding 1 type 0)
You need to add INCLUDE_SNTPC to your vxWorks build to get the SNTP client
stuff that we're now using.
> What about the "no compiler support" comment for this exception, am I
> still missing some
> components in the kernel?
I'm not sure about that, but fix the other problem first.  You may also
need INCLUDE_CPLUS_STRING which I think incorporates the standard C++
exception classes.
> Does my command sequence contain the minimum setup for getting the CA to
> run?
I'm not sure, but I think you have to load munched libraries now or C++
static constructors and destructors won't be run.  Have a look at what the
example application does to generate a single library to be loaded
containing all the necessary object files.
- Andrew
Perfection is reached, not when there is no longer anything to add,
but when there is no longer anything to take away.
- Antoine de Saint-Exupery
CA package(R3-14) on VxWorks/PPC604 Pierre-André Amaudruz
Prev: CA package(R3-14) on VxWorks/PPC604 Pierre-André Amaudruz
Next: RE: CA package(R3-14) on VxWorks/PPC604 Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
