1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: CA package(R3-14) on VxWorks/PPC604
To: [email protected]
Date: Mon, 17 Sep 2001 13:33:53 -0700
Hello there,
I'm trying to get the channel access loaded into my PPC
under VxWorks/Tornado2 to be able to run the "ca_test" for example.
After a successful build of the vxWorks-ppc604 under Solaris
(gnu cross-compiler) for libCom/, ca/ and tools/ directories,
while loading these objects I've got the following result.
-> version
VxWorks (for Motorola MVME2300 - MPC 604e) version 5.4.
Kernel: WIND version 2.5.
Made on Sep 11 2001, 11:15:33.
Boot line: ...
-> ld < ComLibrary.o
Undefined symbol: sntpcTimeGet (binding 1 type 0)
value = 33548192 = 0x1ffe7a0 = oldFdmgr type_info node + 0x18
-> ld < caLibrary.o
value = 33538680 = 0x1ffc278 = caClient type_info node + 0x538
-> ld < ca_test.o
value = 33538120 = 0x1ffc048 = caClient type_info node + 0x308
-> putenv("EPICS_CA_REPEATER_PORT=9003")
value = 0 = 0x0
-> putenv("EPICS_CA_SERVER_PORT=9004")
value = 0 = 0x0
-> ca_test
program
Exception current instruction address: 0x00000000
Machine Status Register: 0x0008b030
Condition Register: 0x44000000
Task: 0x1a842b8 "syncNTP"
C++ exception in file=../../../src/libCom/osi/epicsMutex.h at line=120,
and no compiler support - cant
 proceed.
fatal error: No compiler support for C++ exception
 proceed.
.... hang....
I guess the missing symbol is causing the exception, but I cannot find
the symbol
"sntpcTimeGet" anywhere. Would anyone know where it's coming from?
What about the "no compiler support" comment for this exception, am I
still missing some
components in the kernel?
Does my command sequence contain the minimum setup for getting the CA to
run?
Any help would be appreciated,
Thank you in advance, Pierre-André Amaudruz
TRIUMF                          Phone : (604) 222-1047 x6234
4004 Wesbrook Mall              Fax   : (604) 222-1074
Vancouver B.C. V6T 2A3          E-mail: [email protected]
CANADA                          Web   : http://pierre.triumf.ca/
Re: CA package(R3-14) on VxWorks/PPC604 Andrew Johnson
RE: CA package(R3-14) on VxWorks/PPC604 Jeff Hill
Prev: Re: Error in serial driver Steven Hartman
Next: Re: CA package(R3-14) on VxWorks/PPC604 Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
