1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: 3.14 on Linux
To: Ian A Smith <[email protected]>
Cc: [email protected]
Date: Mon, 24 Sep 2001 12:46:36 -0600
Ian A Smith wrote:
> Hi,
> I'm just about to start an epics project and wonder how advisable it
> would be to try and run 3.14 under Linux.  The only hard records
> required would be an analogue with dev/drv support to talk to the serial
> port of the pc.  All other records would be soft.  I also need dm
> screens and remote CA.
> Is this feasable now or is it known when it would become so?
All of the IOC stuff listed above (and the sequencer too) should work
fine on linux with 3.14-beta1.  I've even successfully run the GPIB/LAN
adapter driver from a Linux IOC application.  I use medm, which seems to
work for the limited amount of stuff I've tried, but I've not tried dm.
How do you plan to communicate with the hardware?  Linux allows
user-level in/out instructions which makes basic device access very
simple.  You need only supply a setuid-root wrapper around your
application to gain access to the range of I/O ports you need.
Eric Norum                                 [email protected]
Department of Electrical Engineering       Phone: (306) 966-5394
University of Saskatchewan                 FAX:   (306) 966-5407
Saskatoon, Canada.
Re: 3.14 on Linux Andrew Johnson
3.14 on Linux Ian A Smith
Prev: 3.14 on Linux Ian A Smith
Next: Re: 3.14 on Linux Matthieu Bec
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Next: Re: 3.14 on Linux Andrew Johnson
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
