Hi Ian,
Sure it is feasible: I'm driving a very simple serial device through
Epics/Linux, haven't seen any problem so far. DM and
channel access also work without problem on that platform.
Other than that, I can't tell if it's recommandable because the release
is still alpha ! maybe it depends on how critical is your system, for us
it's a couple of monitoring devices, so I'm pushing forward for that
kind of solution.
being just next door, I could give you a quick demonstration if you
wished,
Matthieu
Matthieu Bec Gemini Observatory
Tel: +1 808 9742557 670 N. A'ohoku Place
Fax: +1 808 9359235 Hilo, Hawaii 96720, USA
Ian A Smith wrote:
> Hi,
> I'm just about to start an epics project and wonder how advisable it
> would be to try and run 3.14 under Linux. The only hard records
> required would be an analogue with dev/drv support to talk to the serial
> port of the pc. All other records would be soft. I also need dm
> screens and remote CA.
> Is this feasable now or is it known when it would become so?
> Thanks.
> Ian A Smith Telephone: (808) 961 3756
> Joint Astronomy Centre Fax: (808) 961 6516
> 660 N. A'ohoku Place (808) 969 6591
> University Park Web: http://www.jach.hawaii.edu
> Hilo
> Hawaii
> 96720
- 3.14 on Linux Ian A Smith
Re: 3.14 on Linux Eric Norum
Re: 3.14 on Linux Andrew Johnson
<2001>
serial stuff on r3.14 Allan Honey
<2001>
