1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Motor Record with Encoder
Cc: EPICS Tech-Talk <[email protected]>
Date: Thu, 18 Oct 2001 17:33:12 +0200
I am having a problem trying to use the synApps motor record in conjunction with
encoder readback. On the assumption that the problem is trivial, since I find no
reference to it in the listserv archive, I give a brief description of the
problem as an initial posting.
I have set <motor>.URIP = Yes
           <motor>.RDBL = Name of encoder record
           <motor>.RRES = 1.0
The <encoder>.VAL field has the same EGU as the motor.
After the first 2 moves, things seems to work fine. However, when I boot the
ioc, the motor record does not seem to pick up the initial value of the encoder
and its DVAL field is zero. I do not seem to be able to restore the DVAL field
of the motor at iocInit time via the save_restore mechanism.
Have I overlooked something?
David
                               [email protected]
     _/_/_/   _/   _/_/_/     Beamline Group, SLS Project
    _/       _/   _/         Paul Scherrer Institute
     _/_/   _/     _/_/     CH-5232 Villigen-PSI
        _/ _/         _/   Tel: +41 56 310 3616
   _/_/_/ _/_/_/ _/_/_/   Fax: +41 56 310 3294
Re: Motor Record with Encoder Ronald L. Sluiter
Re: Motor Record with Encoder Brian McAllister
Summary: Motor Record with Encoder David Maden
Archive for Tech-Talk Leonard J. Reder
Re: Archive for Tech-Talk Marty Kraimer
Prev: ICALEPCS & EPICS meeting Bob Dalesio
Next: Re: Motor Record with Encoder Ronald L. Sluiter
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: Archive for Tech-Talk Marty Kraimer
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
