1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Summary: Motor Record with Encoder
To: EPICS Tech-Talk <[email protected]>
Date: Tue, 23 Oct 2001 15:59:09 +0200
As a reminder, here is the problem:
> When trying to use the synApps motor record in conjunction with
> encoder readback, I set
>            <motor>.URIP = Yes
>            <motor>.RDBL = Name of encoder record
>            <motor>.RRES = 1.0
> and the <encoder>.VAL field has the same EGU as the motor.
> After the first 2 moves, things seems to work fine. However, when the
> ioc is booted, the motor record does not pick up the initial value of
> the encoder and its DVAL field is zero.
Thanks to Tim Mooney, Ron Sluiter and Brian McAllister for their responses to
this problem. As Brian pointed out, the key to the solution is to note that
writing to the VAL field of the motor record when it is in "SET" mode will cause
it to pick up values from its RDBL field. This feature is described in the small
print of the motor record documentation but I confess that it had passed me by.
Brian also suggested using a sequence record to accomplish this setup. Given the
uncertain nature of some of the time delays involved, I believe that it is
better to use an SNL program to effect the initialisation. For completeness, I
append the source of a suitable SNL program. The program also takes care of the
following two points:
1) The value of the FOFF field should be set to 1 before setting the
   VAL field. Otherwise the setting of the OFF field will get lost.
2) The actual value written to the VAL field is not particularly
   critical. It must, however, lie within the LLM to HLM range of
   the motor. Otherwise the motor record goes into "soft limit
   violation" mode.
David
P.S. The problem of converting the appended SNL program to obtain the name of
the encoder record dynamically at run-time from the RDBL field of the motor
rather than having it supplied as an argument to the seq command is left as an
exercise for the student!
David
**   motorSetup.st
**  SNL program to initialise a motor record from an encoder at ioc boot
**  time.
** Usage:
**   On host:
**              snc motorSetup.st
**              compileppc motorSetup.c
**   On ioc:
**              ld < motorSetup.o
**              seq &motorSetup, "m = Test-Motor, e = Test-encoder"
** Repository:
**    $CVSROOT/PROJECTS/subsystems/X/X04SA/OP2/snl/motorSetup.st
**    $Revision: 1.3 $   $Date: 2001/10/23 13:39:55 $
  program motorSetup ("m = ERROR, e = ERROR")
                    **         Assign variables to channels
  int     ENC_UDF;                 /* != 0 if encoder value undefined */
  assign  ENC_UDF to "{e}.UDF";
  monitor ENC_UDF;
  int     MOT_DMOV;                /* == 1 if motor finished moving */
  assign  MOT_DMOV to "{m}.DMOV";
  monitor MOT_DMOV;
  int    MOT_URIP;                 /* Motor "Use Readout If Present" */
  assign MOT_URIP to "{m}.URIP";
  int    MOT_SSET;                 /* Motor "Set SET Mode" */
  assign MOT_SSET to "{m}.SSET";
  float  MOT_VAL;                  /* Motor "Value" */
  assign MOT_VAL to "{m}.VAL";
  float  MOT_LLM;                  /* Motor Low Limit */
  assign MOT_LLM to "{m}.LLM";
  float  MOT_HLM;                  /* Motor Low Limit */
  assign MOT_HLM to "{m}.HLM";
  int    MOT_SUSE;                 /* Motor "Set USE Mode" */
  assign MOT_SUSE to "{m}.SUSE";
  int    MOT_FOFF;                 /* Motor "Offset-Freeze" if == 1 */
  assign MOT_FOFF to "{m}.FOFF";
  int    foff_save;
  %%   void exit ();    /* Suppress a cc warning message */
  ss motorSetup {
    state init {               /* Wait until encoder setup is complete */
      when (ENC_UDF == 0) {
        printf ("\nLinking %s and %s ...",
          macValueGet ("m"), macValueGet ("e"));
        pvGet (MOT_FOFF); foff_save = MOT_FOFF;  /* Save FOFF */
        pvGet (MOT_LLM);  pvGet (MOT_HLM);       /* Get limits */
        MOT_FOFF = 1; pvPut (MOT_FOFF);          /* Freeze the offsets */
        MOT_URIP = 1; pvPut (MOT_URIP);       /* Tell motor to use enc */
        MOT_SSET = 1; pvPut (MOT_SSET);          /* Go to "Set" mode */
        MOT_VAL = 0.5 * (MOT_LLM + MOT_HLM);
        pvPut (MOT_VAL);                   /* Force motor record update */
      } state waitForMotor
    state waitForMotor {        /* Wait for the motor setup to complete */
      when (MOT_DMOV == 1) {
        MOT_SUSE = 1; pvPut (MOT_SUSE);          /* Go to "Use" mode */
        MOT_FOFF = foff_save; pvPut (MOT_FOFF);  /* Restore FOFF */
        printf (" done\n");
      } state finish
    state finish {when () {exit ();} state finish}
Re: Summary: Motor Record with Encoder Brian McAllister
Archive for Tech-Talk Leonard J. Reder
Re: Archive for Tech-Talk Marty Kraimer
Motor Record with Encoder David Maden
Prev: embedded linux experiences Geoff Savage
Next: Re: Summary: Motor Record with Encoder Brian McAllister
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Motor Record with Encoder Brian McAllister
