1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: The "scanppl" command only works once
From: "J. Frederick Bartlett ([email protected])" <[email protected]>
To: [email protected]
Cc: [email protected]
Date: Fri, 09 Nov 2001 15:05:21 CST
  I have encountered a peculiar problem. The EPICS "scanppl" command
(function) can only be executed once and generate output. The second
and succeeding executions produce no output. This is true both for the
console port and for telnet connections.
  Now it gets interesting. If the telnet connection is terminated and
then reestablished, the "scanppl" command works again (both for the
telnet and console port connection) but still only once. Also, we see
this only for our PPC platforms (MVME2301 and MVME2304); the MVME162
processors allow multiple executions of "scanppl".
  We are currently using version R3.13.4 of EPICS. Anyone have an
explanation?
							Fritz
Re: The "scanppl" command only works once Chris Mayer
Prev: RE: Time Stamps in Channel Access Jeff Hill
Next: et_wish help requested Bill Cruise
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Next: Re: The "scanppl" command only works once Chris Mayer
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
