John,
You might find that it is easier to add the following to your startup
script (before iocInit is called):
putenv("EPICS_CA_ADDR_LIST = 128.84.44.84 192.168.213.148")
Alternatively, you might try quotes around the IP addresses in the
resource.def as follows:
EPICS_CA_ADDR_LIST DBF_STRING "128.84.44.84 192.168.213.148"
I seem to vaguely recall that this also works.
Jeff
> I have just installed EPICS software (3.13.5) and built the example
> application. The iocCore runs and I can communicate with it via the
> console. The client, caExample, runs but is unable to communicate with
the
> iocCore.
> On the host in response to "caExample aiExample" I get the message:
> CA.Client.Diagnostic..............................................
> Message: "User specified timeout on IO operation expired"
> Severity: "Warning" Context: "ca_pend_io failure"
> Source File: ../caExample.c Line Number: 20
> Message: "The request was ignored because the specified channel
is
> disconnected"
> Severity: "Error" Context: "ca_get failure"
> Source File: ../caExample.c Line Number: 21
> The iocCore is on a protected subnet and I am hypothesizing that this
may
> be why the client is unable to communicate with it. I tried to follow
> instructions in the Channel Access Reference Manual, section 1.3.2,
> Configuring CA for Multiple Subnets. However when I add the line
> EPICS_CA_ADDR_LIST DBF_STRING 128.84.44.84 192.168.213.148
> to resource.def ( used by iocInt ) I get an error during iocInit:
> Starting iocInit
> filename="../iocInit.c" line number=599
> Missing resource data type field for resource=128.84.44.84 in
> file=resource.def
> value = 0 = 0x0
> Any advice would be appreciated.
> John Dobbins
> Cornell University - Lab of Nuclear Studies
> tele: 607-255-5740
> fax: 607-254-4552
- Newbie question: example Application John Dobbins
channel access reboot behavior Brian McAllister
<2002>
2025
<2002>
2025
