Greetings to PV gateway users,
Since mid-November, one of our gateways hangs/freezes every now and then.
In the last few days, I've been able to capture some more detail about it
and would like to summarize here in case somebody else has already found
and fixed the problem and would like to share.
We run gateway version 1.2.0 and EPICS 3.13.2 on solaris 8. We've
been running 1.2.0 for over a year with no problems. We use the default
values of the timeouts: connection (1sec), inactive (2min), and dead (2hrs).
Though we run 4 gateway processes, each with a different interface address,
the problem has been identified in just the one that's most heavily used.
I would normally expect less than 10 clients (mostly running DM or DM2K)
and less than 10 servers though eight of the servers (old niCpu030 iocs) are
quite loaded. In early November, our solaris host was upgraded to a much
faster machine. This may be a coincidence. We may also be running more
clients than ever.
A few days ago, I noticed these statistics on the gateway (I haven't
added these PVs to the archiver yet, shame on me!):
Active PVs = 7621606 !!!!!
Alive PVs = 1051
Total VCs = 418 (does VC mean virtual channel?)
Total PVs = 1051
Client Event Rate = 39
Client Post Rate = 33
Exist Test Rate = 0
Loop Rate = 909
Server Event Rate = 59
Server Post Rate = 59
I noticed these errors flooding the gateway log file:
PV not found - Server unable to create a new PV
The only place that would log such an error would be casStrmClient.cc.
It appears to indicate either a memory allocation problem or a pointer
corruption. I expect the problem to be a memory leak in the gateway code.
Restarting the gateway (using gateway.restart) fixes the problem.
And the gateway will then run for days or weeks with no problems.
Normally, #active PVs = #total VCs and #alive PVs = #total PVs. So
the abnormally large number of active PVs is a clue. I've tried (!)
to follow the creation and deletion of PVs and VCs in the gateway code.
I will continue studying it. I will also recompile and run the gateway
with debug lines on.
Any comments would be appreciated. Thanks very much,
Stephanie Allison [email protected]
- Re: PV CAS Gateway Problem Ralph . Lange
Record Reference Manual / calcout record description Benjamin Franksen
betrothed to VAXC? Jeff Hill
<2002>
2025
2026
<2002>
2025
2026
