1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Record Reference Manual / calcout record description
To: EPICS Techtalk <[email protected]>
Date: Thu, 17 Jan 2002 15:44:28 +0100
...contains an error:
5. Output Parameters
     Transition to Zero -- when record is processed, write output only
if VAL is zero and last value was non-zero.
     Transition to Non-zero -- when record is processed, write output
only if VAL is non-zero and last value was zero.
It should be "To" instead of "to" in the menu choice strings. (I
wouldn't mention this, if not for people (including me) who tend to
cut&paste strings from the manual into their db or template files and
then wonder what's wrong.)
Ben
Berliner Elektronenspeicherring-Gesellschaft für Synchrotronstrahlung
(BESSY) GmbH, Control System Group
Albert-Einstein-Straße 15, 12489 Berlin, +49 30 6392 4862, www.bessy.de
Prev: RE: CA Client Diagnostic Message Jeff Hill
Next: PV CAS Gateway Problem Allison, Stephanie
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: search the JAVA extensions for EPICS CA Ralph . Lange
