John,
One possibility is that during this 10-20 seconds some task in
your IOC at a higher priority than the CA repeater is using
all of the CPU. You can use "spyClkStart" and "spyReport" to
see if this is the case.
Otherwise, this might be caused by an unusual port configuration
for the CA client. When you type inetstatShow you should see a UDP
CA repeater daemon on port 5065.
Jeff
> -----Original Message-----
> From: john sinclair [mailto:[email protected]]
> Sent: Friday, January 18, 2002 9:53 AM
> To: tech talk
> Subject: IOC mesage at startup
> Arch = x86
> EPICS = R3.13.4
> VxWorks = tornado 2
> I am getting the following message around 10-20 seconds after an iocInit:
> Unable to contact CA repeater after 50 tries
> Silence this message by starting a CA repeater daemon
> What does this mean?
> Examining VxWorks tasks gives (among other things)
> CA_repeater3e65f04 3cd9650 181 PEND 14db1c 3cd94d8 0 0
> Its seems that this message is a recent occurrence, but I don't think I
> have made any system level changes recently.
> John Sinclair
> [email protected]
> Oak Ridge National Lab
> 865-576-6362 865-574-1268 (fax)
- IOC mesage at startup john sinclair
[no subject] Lynn Foth
LeCroy 4300B FERA search Paul Sichta
<2002>
caTCL with R3.14 and Linux Benjamin Sailer
<2002>
