1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: AO Record: New Drive Limit Mode?
From: "J. Frederick Bartlett ([email protected])" <[email protected]>
To: Kay-Uwe Kasemir <[email protected]>
Cc: [email protected], [email protected]
Date: Tue, 09 Apr 2002 10:54:06 CDT
Kay,
  I would suggest a small modification to your proposal. As in the
present case, there frequently is a need to add a few more "bits" of
behavior-controlling mode to a record.  Rather than adding a new field
every time someone needs to add new "behavior", I suggest adding a
bit-encoded long word to the record and assign the bits, as needed,
from the low-order end.  As problems, like the clamp behavior, arise
the next unused bit(s) can be assigned to hold the new mode state.
  In building an EPICS-based control system for the D0 experiment, I
decided to add a few custom record types to handle the complex behavior
of some of our devices. All of these records have just such a mode
field to handle the class of problem that you have encountered.
						Fritz
AO Record: New Drive Limit Mode? Kay-Uwe Kasemir
Prev: AO Record: New Drive Limit Mode? Kay-Uwe Kasemir
Next: Re: AO Record: New Drive Limit Mode? mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: AO Record: New Drive Limit Mode? Andrew Johnson
