1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: AO Record: New Drive Limit Mode?
To: [email protected]
Date: Tue, 9 Apr 2002 10:55:26 -0500 (CDT)
re...,
> Some users here at LANL had a suggestion that's actually useful.
> The problem is about entering "wrong" values from a GUI,
> that is values outside of [DRVL, DRVH].
> Per default, the AO record would "clamp" the value, e.g.
> Value > DRVH    ==>   value = DRVH.
> This can lead to jumps. Example: [DRVL,DRVH]=[0...10], current value 0.5.
> User wants to make it 0.6 but accidentally enters 60
> ==> You jump to 10. That's a big jump from 0.5!
> Just staying at 0.5 and allowing the user to try again
> might be better.
> Solution: New AO field DRLM - "Drive Limit Mode"
> Possible Values:
> a) "Clamp" (default)
> As before, any value outside of DRVL ... DRVH
> is clamped/changed to DRVL or DRVH.
> b) "Reject"
> Any value outside of DRVL ... DRVH
> is rejected. The record returns to the
> previous value (still available in the OVAL field).
That would be nice.  I'd even argue that "reject" should become the
default.  It would be confusing, though, if you wrote "10.0" to a
record whose DRVH appeared (PREC=1) to be "10.0" but actually was
"9.996".  A user would want some indication of why the value was being
ignored, or they'd just reboot the crate and claim EPICS had "crashed".
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls & Data Acquisition Group
Advanced Photon Source, Argonne National Lab.
Prev: Re: AO Record: New Drive Limit Mode? J. Frederick Bartlett ([email protected])
Next: Re: AO Record: New Drive Limit Mode? Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: AO Record: New Drive Limit Mode? Bob Dalesio
Next: RE: AO Record: New Drive Limit Mode? Redman, Russell O.
