1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: DM to EDM
To: tech_talk <[email protected]>
Date: Tue, 30 Apr 2002 12:50:08 -1000 (HST)
Appended is a short Perl script that takes a hack at converting edd/dm adl
files into medm adl files. It isn't perfect, but it generally does an
acceptable job. It handles obvious things like the row and column order
interpretation is different, and changes a few names where they don't
apply. You have to make sure you do the global template file first, if you
use that sort of thing.
Some things in edd/dm don't have a corresponding counterpart in medm, so
it is difficult to convert perfectly. I see this as more of a work in
progress than anything else - it may not work for widgets we don't use,
for example. However, at JAC we use it - I installed it and changed the
edd/dm make rule so that it installed both an edd/dm *.dl file and an medm
*.adl file so you can run up either display manager. Ths helps me out
since edd/dm crashes my PC X server, for example.
However - this is not the edd to edm converter people want. On the the
hand, someone mentioned edm supporting an medm input format, and surely a
similar translator that goes straight to the edm format is not too
dificult for a good Perl hacker.
Cheers,
Nick Rees
Joint Astronomy Centre               Ph:       +1 (808) 961-3756
660 N. Aohoku Place                  Fax:      +1 (808) 961-6516
Hilo, HI.  96720                     Internet: [email protected]
#!/usr/bin/perl
use strict;
#use warnings;
my @states;
my $state;
my $index;
while ( my $line = <STDIN> ) {
#  Check to see if we are at the beginning of a block
  if ( $line =~ /^\s*"?([^\["]+)\[?([0-9]*)[\]"]*\s*{/ ) {
    push( @states, ($state,$index) );
    $state = $1;
    $index = $2;
#   print "State = $state, index = $index\n";
  my $output = $line;
  chomp $output;
  for ($output) {
      s/stacking="row"/stacking="temp"/;
      s/stacking="column"/stacking="row"/;
      s/stacking="temp"/stacking="column"/;
  if ( $state =~ /related display/ ) {
    for ($output) {
      s/menu_title=/label=/;
  elsif ( $state =~ /toggle button/ ) {
    for ($output) {
      s/toggle button/choice button/;
  elsif ( $state =~ /message button/ ) {
    for ($output) {
      s/inactive_label=/label=/;
  elsif ( $state =~ /display/ ) {
    for ($output) {
      s/\.dl/.adl/;
    $output = "" if ( $index > 7 );
  print "$output\n" if $output;
# Check to see if we are at the end of a block
  if ( $line =~ /^\s*\}\s*$/ ) {
    $index = pop( @states );
    $state = pop( @states );
Re: DM to EDM Rolf Keitel
Prev: Re: 3.14 questions (memory footprint) Alan K Biocca
Next: Re: VDCT - Visual DCT Jim Thomas
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: DM to EDM Rolf Keitel
Next: about VDCT Xuedong Chai
